Old 11-11-2018, 05:09 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Default What program
Mountainride, what app or program are you laying that panel out with?
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2020
Old 11-15-2018, 08:07 AM
mountainride mountainride is offline
autodesk fusion (It is free)
RV-14 N303XC : Flying
Old 12-28-2018, 09:42 AM
ColoradoSolar ColoradoSolar is offline
Where did you get all the 3d models?
Old 01-14-2019, 01:47 PM
infltc2s infltc2s is offline
Default Garmin Panel
https://flic.kr/p/23B3fNX
RV-14 Flying
N352AL
Texas
Old 01-17-2019, 02:39 PM
rwthompson67's Avatar
rwthompson67 rwthompson67 is online now
Old 01-19-2019, 10:51 PM
dmattmul dmattmul is offline
Default Back-up EFIS
rwthompson67, Did you need to go with the Garmin back-up EFIS because the Dynan would not fit? I am about 3 months away from ordering my panel (SNF 2019 will decide) and torn between Garmin and Dynan for the PFD's. The Dynan (and MGL) are slightly wider than the Garmin and it's pretty tight in that space. One nice "feature" of using Dynan the AeroRocker switches will fit. I am pretty sure if using G3X I don't think the AR switches will fit under the display. Thanks
RV-14A QB building, Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, Parts became a real airplane 8/15/2020.
Started RV-10 Nov 2020. Empennage arrived (Built) Working on QB kits. Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 3 blade, real airplane hopefully early 2023.
Old 02-23-2019, 10:14 PM
Bavafa Bavafa is offline
Here are a few pictures of my panel and interior. The panel is not nearly as white in actual as it appears here.
Classic Aero has done a great job with the seats
Home made side panels and glareshield
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 02-24-2019, 04:15 PM
I went with the G5 because it was a lot cheaper than the D10A and I like the look. Also wanted to kind of split my panel up 50/50 between Garmin and Dynon.
Old 02-25-2019, 06:02 PM
tfoster100's Avatar
tfoster100 tfoster100 is offline
This is my new favorite panel and interior. Couple years away but I love the look all the way around.
Tim Foster
Dues paid thru 2021
Building RV-14a kit # 140381
On wheels and making progress
182 Sold 😂
https://eaabuilderslog.org/?s=tfoster
Old 03-04-2019, 02:25 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Finally, everything attached and mounted on panel and behind panel, VP-X Pro with configuration transferred, Master Switch ON, Avionics Master ON. Hold breath and step back . . .
No smoke or sparks.
VerticalPower VP-X; ACK ELT, Garmin - G5, GDU465, GMC507, GTN650, GTR200, GMA245, GDU470, GTX45R_emote.
Now on to a few small buckets of airframe finishings up, gear leg fairings, wheel pants, etc, etc...
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
RV14A (N14ZT), Ser#140195
Start 10/11/14; AWC Rcvd 7/21/21
Contribution made 12/2/20 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
