Previous thread (https://vansairforce.net/threads/13-row-oil-cooler-inlet-exit.228040/):
I have some update that I hope someone can help me diagnose my high oil temps. 200 deg during cruise at 55% power. My neighbors Pawnee that tows gliders at 65 KTS and has a small oil cooler cannot get the temp past 140 deg.
-Started with oil cooler and plenums as standard Van's setup. The IO540 is also all standard, no piston squirters and no high compression cylinders.
-I have checked the oil pickup tube in the sump, the Vernatherm for proper extension and wear sign on the cone, replaced the oil lines, replaced the oil cooler to Pacific Oil Cooler and then to Airflow performance 13 row oil cooler with their modification that includes enlarging the oil cooler plenum and installing a baffle in the plenum. I have made these changes one at a time to pinpoint the cause but no appreciable changes noted at each step.
-I have checked the oil temp probe and wiring and found a bad connection that improved my oil temp indication by 10 deg. I also checked the oil temp within the sump immediately after shutdown and found it to be within one degree of the Display temps (I know it is supposed to be hotter but not on my engine). I see 200 deg at 55% power during cruise flight. CHT temps climb to 400-420 in a long climb but settle to 360-380 during cruise.
-I have made sure that all my baffles are good by looking through the joints with a flash light. I have had others check my baffles too.
-I replaced the 90 deg oil cooler adopter with Lycomig's original design to eliminate any Vernatherm misalignment with the sealing surface.
I am at the end of my rope!
Pete Howell, on this Forum, loaned me a bluetooth temp recorder. (thank you Pete). I ran a test yesterday and I have attached the results. It looks like my oil cooler drops the temps up to 35 Degrees during climb but only 10 deg during cruise. Pete thinks it has to do with the airflow. Makes sense but I appreciate another set of eyes.
Sorry for the long post. I hope someone that loves to look at data will chime in. Thank you in advance.
Rob.
Rob.
