Scott's RV14A: N52XL
MIlestone! Installed the canopy. I takes three people. One inside to guide the canopy release pin into the canopy hinges and two people on either side to guide the canopy into the hinges while holding it upright.
So, now it's on to finishing the wings!
Started back in to completing the QB wings. I have to close up the bottoms and install one access panel on the port side. I'll do the access panel first because it's pretty easy and I'm not sure how to reach all the rivets on the bottom skins, so something to think about.
On May 11 I started the process of closing up the lower skin on the starboard wing. I took some photos of the wing before closing it up so I would have documentation of how the autopilot is installed and wiring is routed in this area. The photos follow.
Wing Starboard A:P Exposed.jpg
On May 11 I started working on figuring out how to rivet the bottom skin on the starboard wing. Turns out that reaching the most forward rivets isn't that difficult for one person if the skin is curled back and held in position with rachel straps.
Wing Starboard Lower Skin Riveting.jpgWing Starboard Lower Skin First Rivets.jpg
On June 5 the starboard wing was assembled and ready for painting. I started by scuffing the whole wing with maroon Scotchbrite. Then, I applied wash primer to the bottom of the wing. Tomorrow, June 6 I flipped the wing over and shot wash primer on the top.
On June 6 the wash primer was completed and the urethane primer was applied to the top of the wing. On June 7 the urethane primer was applied to the bottom of the wing. Harriet and I competed in the Glenwood Rally in the MGB over the weekend, then on June 11 I sanded the urethane down in preparation for painting.
After the urethane was sanded with P400 the paint was applied to the top of the wing. On June 12 the bottom was painted.
Over the past week from June 13 to the June 20 I cut and buffed the wing. Then, I attached the aileron and wingtip and cut and buffed them.
I decided to paint the wingtips where the landing and position lights go silver to match the fuse. I did this yesterday, June 26. 4 hours. Today, June 27, I assembled the wingtips landing and position lights and attached the wingtips to the starboard wing. Harriet helped me put the flap on yesterday. 3 hours.
Cowl Bodywork Completed
Got all the bodywork done on the cowls with the side pins hidden under the RV14A plaque. Everything fits well and the pins and Skybolts all go in with no issues.
I used the same pin hinge covers as these on my RV7. What did you do with the ends of the hinge pins behind the covers? Thanks Kloot
Attached the baffles.
Started fitting the snorkel. It was too wide by 3/4". So, I cut it in half and took a section out in the middle and epoxied/floxed it back together. After some bodywork, it looks pretty good. Primed it today and will paint it tomorrow.
I decided to add an extra access port in the bottom of the port wing. Two reasons: 1) obtain better access to the pitot and AOA hoses and wiring of the pitot heater and, 2) obtain better access to rivets for riveting the pitot tube and the forward-most skin rivets which otherwise can't be reached (at least by me).
Thanks to Wirejock for the hole cutter. It did the trick.
I'm back! Not much to report in past month or so. Just cutting and buffing paint and moving everything except fuse to the hangar. There is a LOT of real estate to cut and buff! Not much like a car.
Anyway, working on bleeding brakes which is way a lot of fun. Needed a break. So, I installed the Aircraft Specialty alternate air door. Very nice piece, as usual from these guys. Way better than the OEM door. It took a little trimming to make it fit but it works very slick.
During a review by my bud who is an A&P, he suggested I move the Adel clamp off the flare nut to the fitting. Reason was the fitting is less likely to turn than the nut.
I presume you mean the 90 degree coming off the head? I agree. I never liked the clamp on the nut, either. Thanks. S
I have no idea how that nut could spun off.. the adel clamp works like a wire safety to my perception... it is tight and the alternate air cable wont just let the assembly spin. But do what the A&P says.
The nut doesn’t have to spin off, just get loose for a leak to occur. Probably would never loosen the nut but not a good practice. And if I get a DAR like Mel, one less thing for him to find.
I wasn't happy with the paintwork I did on the lower cowl after cutting and buffing it. So, rather than wish I had redone it when it was in the shop, I sanded it all down and repainted it. This time, I got the lighting so I could see what I was painting (important) and it turned out much better. A little cutting and buffing will make this part look like the upper bits. Almost there........!
How did you go about painting the rest of the fuselage? I'm thinking about how to tackle it. Seems like it is going to be a challenge to paint the underside and have enough space to get in with a creeper. Also to be able to paint a complete "lap" around the fuselage before the paint flashes off and makes it difficult to avoid overspray settling on. Where on the fuse did you start and end spraying to meet up with the "wet edge"?
Cheers
Paul
Cheers
Paul
Paul,
Painting the belly was not as difficult as it might seem, although it is a lot of real estate. The fuse is pretty high up, so a creeper is all that is needed, although I just sat on the floor of my shop and slid around. I adjusted my paint with slow flashing reducer and painted at an average temperature of 65F, so by continually moving, overspray was kept at a minimum. I use an Anest Iwata LPH400 gun and orange air cap for colors and silver cap for clears. I painted the centerline of the belly and worked outward. That way, the overlap orange peel is at the very center, underneath, and less noticeable. It's no different than the way you would shoot a large car. Some cutting and buffing is inevitable, though, to get a perfectly flat finish if that is the goal.
Paul,
Thanks Scott
The LPH400 looks like a nice gun and the HTE should help with overspray reduction I expect.
The belly is a big expanse especially under the cockpit and baggage area. I can't really visualize how to work underneath and then come out and up the sides while spraying as it seems there would be a bit of scrambling to get out from underneath to spray up the sides. I'm thinking of maybe spraying the belly first and then masking it off when it is dry (along the natural seam lines) before spraying the fusealage sides and top.
p.s. if I can paint early in the day the temps will be cooler so it doesn't flash off too fast, I will also try slow reducer and activator, the down side of that will be more potential for runs and dust getting in...
Thanks Scott
That's a good plan. In fact, unless you have a 44 oz cup on your gun, you'll need to change cups halfway through. I used two 22 oz cups to cover the belly and halfway up the sides of mine. Two cups works well, but if you are using Sherwin Williams, like me, the paint needs to react with the activator for 15 mins before spraying. Logistics gets tricky. Shoot the belly. Then shoot the sides and roof. The overspray along the underside can be cut and buffed and out of view unless observed from below. So, unless you're planning on inverted flying with spectators flying above you, looking down, it won't be visible.
I've got the 3M PPS cups, 600 ml, the paint is Valspar (Sherwin Williams) single stage polyurethane that doesn't require any induction time. Still, I've been caught out on some smaller parts when I had to stop and mix more paint and by then the previous coat was already flashed off and it was difficult to get a good finish. The standard reducer flashes off quickly at 25 C but there is a slower speed activator and reducer that will hopefully work out better on the bigger parts. This paint seems to lay down and flow out better when it is warmer, even though it flashes off a bit too fast before the next coat.
Milestone!
Finished bleeding the Beringer brakes today. My buddy Larry and his wife did the lion's share a week ago and we were still getting air after 1.5 hrs. I left it sit for the past 6-7 days and finished the job today with my girlfriend. After eight pumps of the left then the right pedals we got no more air and very firm pedals. Whew! Glad that's over!
Onward to de-oiling the engine of preservative oil and moving the fuse to the hangar!
Painted the steps with Wing Walk Compound yesterday and unmasked them today. Came out nice. The color is called black, but it's really very dark gray (charcoal). Anyway, it works well with the rest of the livery, I think. The stuff is basically paint with lots of sand in it. Takes a lot of stirring to get the sand up from the bottom of the can, but not bad. Put it on with a disposable brush from Ace. It takes about 4 hours to cure. I used about two brushes semi full for the steps. The wings will take a bit more, but I will have lots left over for touch ups, if needed. The smallest quantity from Spruce is 2 qts for $32, so if anyone wants some, I'll be glad to share a quart for $16 plus shipping.
Color sanded the lower cowl that I repainted a few days ago. Did a little comparison. Lower left is sanded with 1500 Trizac wet with my rotary air polisher. The rest of lower cowl is sanded with 1500 wet or dry by hand with a flexible pad. I sanded it until virtually all of any orange peel present was eliminated flat except for the aft portion between the exhausts which I left as painted with whatever peel was there after painting. We'll see which way polishes out the best.
It's been awhile since my last post, so here I go to catch up. Lots has happened since last year. Mostly, I moved the whole assembly operation from my home shop to my hangar at KFNL. This happened in September '24. Here's how we moved her.
By November of '24 I got the wings attached, wiring and fuel and pitot and ADHRS connected to fuse. I think this means she is 95% completed and only 95% to go!
June 3, 2025. Got her up on jacks to level so fuel flow could be measured in this attitude. At the same time, measured the distances from the centerlines of the wheels to the CG datum 72" forward of the wing leading edge. This information, along with the empty weight will be used to calculate the weight and balance data. Fuel flows came out to about 60 gph for both pumps in the level configuration and when the tail was lowered to the ground (about 15 degrees from horizontal) to simulate the maximum takeoff angle. Since 20 gph is maximum fuel burn on takeoff, we are easily within the 125% of max fuel burn required.
Next up. Engine start.
June 14, 2025. First engine start. Everything went very well. Only issue was that rpms seem high. At full idle and engine sounding like it was running at about 500 rpm the PFD reading was 1400. And, when readings were 2750 rpms on the PFD, the throttle was still an inch from the panel. So, something is amiss. But, oil pressure was in the green. Fuel pressure read in the yellow, though. CHT's were 245 to 260F after 5 mins. Forgot the look at EGTs.
Probably a case of you needing to set your engine monitor at two (2) pulses per revolution.
I didn't check but what ignition are you running? If PMags, I am pretty sure you need to set that.
Also, what engine monitor?
Of course, I could be wrong.
PMags. Dynon EMS.
I haven't posted in a while, and a lot has happened. Got my AWC. Did transition training in both an RV7A (with a CFI) and an RV14A (for comparison). Since then, I have been putting the ship back together after being apart for the DAR inspection. The interior took some time. MANY machine screws!
I have taxied around my hangar area a couple of times and noticed a rough idle, or tendency to die, if a pulled the throttle all the way back. So, I adjusted the idle to about 800 rpm and got a relative rough idle. And I noticed that the mixture control in the cockpit had a huge effect on running. So, I embarked on adjusting the mixture at idle since rpms are supposed to increase 50 rpm on leaning from idle and mine was increasing 300 rpm! A little out of wack. The process is one of trial and error and takes a while. The good news is I got really good at hot starts. Anyway, after fiddling with the idle adjustment and mixture turnbuckle, she idles at 800 now with a 50 rpm increase on leaning. This is what my idle adjustment turnbuckle looks like at my field in my plane. The turnbuckle is really sensitive. turning it one flat changes a lot. This is in contrast to the idle adjustment. 3 turns gets me 100 rpm. For my ship, idle is about 1.5threads showing on the idle adjuster and about 5 threads showing beyond the jam nuts on the mixture turnbuckle. For those of you playing with this, these positions should get you in the ballpark. From the factory, mine was way rich for me at 5280 MSL.
Congratulations!
Out here in the lee of the Rockies, virtually any wind aloft above low single-digits will give you up and down air motion, up to 400 miles east. It's very hard to get still air. Fortunately you don't need to complete that card all on one flight.
Also I'd recommend waiting a couple minutes or longer after turning to let things settle down.
Dave
