The VAF News - 9.2.2024. #6160. WDYDWYRTW, low-voltage, intake seals, seat ventilation, worktable, roll servo.
DeltaRomeo
doug reeves: unfluencer
Staff member
Hope you had a nice RV Sat/Sun and that your RV Mon is going well. Reminder: Mothership closed today (Labor Day).
v/r,dr
dr
Why I love this site!!!!
…..bjdecker type replies below….
“Install the breather IACW the plans -- see OP-27 (attached)”
Rjmvmi1998
kirkbauer
Mikeyb reply on IO-360 M1B Intake Tube Seals - Backfiring
I took an input tube off to install an inverted oil line. The O-ring on the tube sits close to the inside edge of the hole in the case. The inside edge of the hole is not chamfered like the outside edge and has a small radius edge. It’s very easy to get the tube It in too far as you are connecting the tube to the head. The tube and oil lubricated O-ring slide into the chamfered end easily. Go a 1/4” too far and no amount of lubrication will protect the O-ring as it slides across the edge being pulled back. Fortunately I bought an extra $14 O-ring. If I did it again I would hose clamp a stop to the tube before I removed it to keep it from falling in.
SkyDweller
HFS
jull_under
Q: …NickZ
A: …Jesse23
OFF TOPIC:
