Hope you had a nice RV Sat/Sun and that your RV Mon is going well. Reminder: Mothership closed today (Labor Day).
v/r,dr
dr
vansairforce.net
![Screenshot 2024-09-01 at 4.14.21 PM.png Screenshot 2024-09-01 at 4.14.21 PM.png](https://vansairforce.net/data/attachments/48/48138-9f6878c507a474fd95e3644071067435.jpg)
Why I love this site!!!!
…..bjdecker type replies below….
“Install the breather IACW the plans -- see OP-27 (attached)”
vansairforce.net
![Screenshot 2024-09-01 at 9.04.59 AM.png Screenshot 2024-09-01 at 9.04.59 AM.png](https://vansairforce.net/data/attachments/48/48136-c16ba8dee125aac42acaadc22911208e.jpg)
Rjmvmi1998
vansairforce.net
![Screenshot 2024-09-01 at 9.03.43 AM.png Screenshot 2024-09-01 at 9.03.43 AM.png](https://vansairforce.net/data/attachments/48/48135-135ea74d5af41dda972550047be8b3bf.jpg)
kirkbauer
vansairforce.net
![Screenshot 2024-09-01 at 9.06.07 AM.png Screenshot 2024-09-01 at 9.06.07 AM.png](https://vansairforce.net/data/attachments/48/48134-10fe6d96694bb51e37c79499a0e1eb60.jpg)
Mikeyb reply on IO-360 M1B Intake Tube Seals - Backfiring
I took an input tube off to install an inverted oil line. The O-ring on the tube sits close to the inside edge of the hole in the case. The inside edge of the hole is not chamfered like the outside edge and has a small radius edge. It’s very easy to get the tube It in too far as you are connecting the tube to the head. The tube and oil lubricated O-ring slide into the chamfered end easily. Go a 1/4” too far and no amount of lubrication will protect the O-ring as it slides across the edge being pulled back. Fortunately I bought an extra $14 O-ring. If I did it again I would hose clamp a stop to the tube before I removed it to keep it from falling in.
vansairforce.net
![Screenshot 2024-09-01 at 9.07.17 AM.png Screenshot 2024-09-01 at 9.07.17 AM.png](https://vansairforce.net/data/attachments/48/48133-de1cda65889ca63cdcdc73c19a85ba56.jpg)
SkyDweller
www.vansairforce.net
![Screenshot 2024-09-01 at 9.07.57 AM.png Screenshot 2024-09-01 at 9.07.57 AM.png](https://vansairforce.net/data/attachments/48/48132-4bf99a26014a0d55cb22158c8ba9e83b.jpg)
HFS
vansairforce.net
![Screenshot 2024-09-01 at 9.09.59 AM.png Screenshot 2024-09-01 at 9.09.59 AM.png](https://vansairforce.net/data/attachments/48/48131-f0d0cd14e3f31e38e6b582252606e403.jpg)
jull_under
![Screenshot 2024-09-01 at 9.10.55 AM.png Screenshot 2024-09-01 at 9.10.55 AM.png](https://vansairforce.net/data/attachments/48/48130-41c7e63016685848509dc840bc260fb0.jpg)
Q: …NickZ
vansairforce.net
A: …Jesse23
![Screenshot 2024-09-01 at 9.11.48 AM.png Screenshot 2024-09-01 at 9.11.48 AM.png](https://vansairforce.net/data/attachments/48/48129-3e7e089c63498b56b7b1788a197673d0.jpg)
OFF TOPIC:
![Screenshot 2024-08-31 at 11.11.13 AM.png Screenshot 2024-08-31 at 11.11.13 AM.png](https://vansairforce.net/data/attachments/48/48128-05f9589d86f94ece6da80c77ed1c8511.jpg)
vansairforce.net
v/r,dr
dr
WDYDWYRTW? (8/31 - 9/12024)
...getting this week's 'What did you do with your RV this weekend?' thread started. v/r,dr
![vansairforce.net](https://vansairforce.net/data/assets/logo/vaf-icon-192x192.png)
Breather line and oil blow by.
Gentlemen, Here are a few pics I snapped today of my crankcase breather line. I’ve gone from 7 to 4 qts in 13 hrs, with most being blown overboard. I realize I overfilled at the oil change but I’m concerned at my oil use. I went over the engine pretty well this morning and found no real...
Rjmvmi1998
Low Voltage Warning Etched Circuit Board Modification.
I have one of the early AeroElectric Connection Low Voltage Modules installed in my plane. I want to try and modify it. I installed EarthX batteries and as you know the resting voltage is around 13.5V. The LVM was designed for lead acid batteries and doesn’t engage until it detects 13V...
kirkbauer
Section 27 (Firewall) Issues
F-1001G-L and F-1001G-R are mirror images of each other, including the hole pattern for a nutplate (see my photo below). But on page 27-5 (also in photo below), it only shows a nutplate on the right side. Unfortunately, I think that I match-drilled the #12 hole through F-1001A (the firewall) and...
Two things. First question. Does anyone have advice or a written procedure for replacing the intake tube seals on the sump end of the tube? Photos below. I have gotten some great advice from a respected member of VAF about trouble shooting my problem but just casting a wider net. Second...
SkyDweller
Seat Ventilation Harness
Hi All, first time posting for help, hope I’m in the right place! I purchased a RV-9A earlier this year (first plane had to be an RV!). It came with 6 ventilation fans built into each seat, though they are not hooked up. I was provided two harnesses by the owner. There three wires which need...
![www.vansairforce.net](/proxy.php?image=https%3A%2F%2Fwww.vansairforce.net%2Fdata%2Fassets%2Flogo%2Fvaf-icon-192x192.png&hash=253ac26c64e15348dec9ea91bd1c9a3e&return_error=1)
HFS
Alternate Use of Work Table …
My work table converted to a candy “kitchen” - Macadamia Brittle. Almost as much fun as building an airplane… HFS “The Candy Man “
jull_under
Roll servo installation question ?
Hello all. I’ve seen the roll servo installation where you fabricate a bracket and install to the front stick. Did anyone install the servo by attaching directly to the aileron pushrod. What if I mount the servo on its side and run the pushrod directly to the pushrod. I’ll have to install a...
Q: …NickZ
Where are the jack/lifting points for Rv-10 mains, front tire change?
Best and safest lift/jacking up points for Rv-10?
OFF TOPIC:
Doug's Area ....The VAF News & my flying resume.
The VAF List ...a list of RV-related lists. RV-related things you might want to browse over (a closed post that is sticky and maintained by dr). Link to this in 'Links' in the menu. v/r,dr Small biz that brings you this page: 360 Avionics www.360Avionics.com Aircraft Extras...
