Weekend done already! Worked side gigs roughly half of the last 72 hours so I’m fairly pooped - weekend went crazy fast <g>.. Multiple sims this week - the RV sits in the corner looking confused ;^). I miss it too!
Hope you have a great Monday and got to spend some time with your RV Saturday and/or Sunday!
v/r,dr
dr
RV-12 Garmin EGT and coolant temps.
…rcarsey
Here is a climb from 1000' to 9500' (with a level off at 7500' for a couple minutes). You can see the EGT increase when it went back into ECO mode. The coolant temperatures are only ever a problem while on the ground and idling for too long -- in which case, increasing your RPM to 3000 gives enough air movement to return the temps well into the green.
SkyDweller
RV7 To Go RV-8 Status Update
She's dressed now! Wings shown before clear coat. A couple days of curing time before starting final assembly. Getting close!
Mark Cigal
inktomi
Roadjunkie1
Av8torTom’s iPad Rig
I got the smallest RAM mount with a 1" ball at each end. Attached one end to the panel, and (believe it or not) Velcro to the other end, and a couple strips of Velcro on the back of my 10" iPad. I've been in some pretty good turbulence and it's rock steady. The Velcro allows fine tuning placement
RV8 Terry Bursh strakes
OFF TOPIC:
v/r,dr
dr
WDYDWYRTW? 10 / 26-27 / 2024
....getting this weekend thread started. Hope you have a wonderful one! v/r,dr
www.vansairforce.net
…rcarsey
For those of you flying the Garmin quip'ed iS, what are you commonly seeing for your EGT and coolant temps at full power?
vansairforce.net
SkyDweller
RV6 O-360 loss of power on takeoff
A friend of mine had experienced an intermittent power loss on takeoff today (landed safely). Will outline below. O-360 with dual Pmags and CS prop. After the failure and some checks he performed multiple full power run ups and everything was normal. ANY recommendations on other items to...
vansairforce.net
Show us the status of your 8/8A project!
This is correct. My battery (EarthX) is on the firewall, I have an RV200 composite prop and the grove one piece gear. CG with me, wife, fuel and baggage will be right around 83”. Sorry all, I had a Homer Simpson moment (Doh!) :D Of course the CG will move rearward with fuel and people...
vansairforce.net
Mark Cigal
Today I had to say goodbye
Yesterday was a very difficult day. On August 23rd 2004, after 3 years and 4 months of construction, Miss Claire and I got airborne for the first time. Twenty years and one month later, hurricane Helene completely destroyed my beloved RV8. During those years she introduced me to many fine folks...
vansairforce.net
inktomi
Should I replace this nutplate?
Hi - I feel silly asking this, but I'm curious about a couple things: a) How do you get into little spaces to set rivets? There must be a tool I don't have, because I did this nutpate twice and still it's really bad. b) Should I replace this nutplate (again)? I know that the rivets on...
vansairforce.net
Roadjunkie1
The Genius of Design
I was sitting in front of SuzieQ’s port wing the other day having just completed my pitot/static check and was on my short shop stool just looking at this well-designed aircraft from a different perspective. I suddenly became aware of just how amazing the airfoil on this airplane is! Not only is...
ipad panel mount
Anybody aware of an Ipad flush panel mount like an Air Gizmo which also swings out at an angle so the pilot can view when the Ipad is on the copilot side? Big ask for the big vans universe! :)
vansairforce.net
I was in Oshkosh this year and met up with some of the guys who have answered my call for info on RV8 strakes . I also acquired a pair from Terry Burch which I have fitted and flew an air test today . I am very happy to report that they have reduced my clean and full flap stall speeds by 3...
vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
