Here is a climb from 1000' to 9500' (with a level off at 7500' for a couple minutes). You can see the EGT increase when it went back into ECO mode. The coolant temperatures are only ever a problem while on the ground and idling for too long -- in which case, increasing your RPM to 3000 gives enough air movement to return the temps well into the green.
Here is a climb from 1000' to 9500' (with a level off at 7500' for a couple minutes). You can see the EGT increase when it went back into ECO mode. The coolant temperatures are only ever a problem while on the ground and idling for too long -- in which case, increasing your RPM to 3000 gives enough air movement to return the temps well into the green. View attachment 72908
