Garmin EGT and coolant temps.
philcam
For those of you flying the Garmin quip'ed iS, what are you commonly seeing for your EGT and coolant temps at full power?
Phil (@philcam), I have a Sling LSA, so not identical, but still Rotax 912iS.
** EDIT: Previous reply had incorrect data.
This is from my last flight, which I think it's representative. Engine has 105 hours so far.
Here is a climb from 1000' to 9500' (with a level off at 7500' for a couple minutes). You can see the EGT increase when it went back into ECO mode. The coolant temperatures are only ever a problem while on the ground and idling for too long -- in which case, increasing your RPM to 3000 gives enough air movement to return the temps well into the green.
Thanks Rob, I sent you another email.
