Yes, if you get 80/80 there is a good chance you have a 0" ring gap and cracked rings are in you near future. It is theoretically impossible to get MORE than 80 PSI of measured pressure with an input pressure of 80, assuming the piston is not moving, hence the comment about inaccuracies in the gauge. This is an issue with superior, as they ship their rings oversized and expect the installer to file them down to size. Major opportunity for errors, as Lyc ships them pre-sized. Easy to forget if you usually use Lyc.Superior mentions in one of their talks that having 80 compression (or very close to it) on a mid time engine is a concern that the rings were not installed correctly. he sounded like it's a bigger concern than if you see 60s.
Very easy to create offsets for gauge inaccuracies. With the tester not connected to plug adapter, run the input up to 80 and read the other gauge. Your offset is 80 +- whatever the indicated gauge reads. Mine reads 2 PSI low, so I just add 2 to each measured result.
