At this point I think it's a near certainty that the issue was a faulty switch, and that replacing the switches with something that is more reliable with lower current and voltage levels will address the issue (such as gold plated contacts).
Also, someone on this thread asked how I can explain the majority of VPX users not having any issues, another pointed out that experimental means build it anyway you want, and a third suggested that there was no data that points to the system being sensitive to installs and concluded that this wasn't the place for any risk analysis.
I respectfully disagree:
1. Airplanes aren't the place for "most people aren't having problems". If only a few people had cracks in their crankshafts, we would want to know about it, not ignore it on the basis that most people haven't had issues.
2. Yes, you can build your airplane any way you want, but I think people should understand the modes of failure to make informed decisions, and if there was a failure that caused a crash, that affects us all. If nothing else, insurance rates....
3. If there isn't data pointing to the system being sensitive to installs, then why is it common knowledge that it doesn't tend to play nice with plane power alternators? Also, this isn't the first we've heard of noise issues with someone else having their VPX shutdown due to a noisy usb power brick. Something that runs on a microcontroller is going to be more sensitive than a fuse and a switch, because: physics.
Least this be viewed as off topic, let me point out that I learned something from this thread and my mind was changed.... I have a BandC PMR1D regulator for my secondary electrical system and apparently the on signal is only 60ma going through a switch. This means my secondary electrical system could end up failing if the switch gets dirty, so I'm going to order a gold plated switch to replace the one I have.
Is this needed? Probably not, but the last time I had an alternator failure I had to hand prop my airplane was here:
https://maps.app.goo.gl/7Vxo7nQfvAKWdJtD9
