I really did not want to make these troubles public but when I can't get any help to solve it, this was the last choice. I want to be clear that Josh at Stein has been so helpful and has always stepped up to help but he is out of ideas as well.
A bit of back ground. I have been flying the new panel for just short of 2 years. For a full year and over 100hrs of flying I had zero issues. Then I started getting a power supply issue. The first was an audio panel cutting out. At the time we did not think it was power as it wouldn't power off but I would loose Audio. The audio would flash crew I think. VPX ensured it wasn't their unit and Garmin stepped up to the plate and changed the audio. Problem was gone for a few flights and returned. When Nav/com 2 started dropping out, I knew it was a VPX issue. Garmin did some testing and notice that crew would flash when there was an intermittent power loss. I swapped wires on the VPX to a totally different terminal and was able to get it to work without dropping out.
I tried to do and exchange of the VPX. VPX would not do that so I wasn't wasting time and just bought a new one. It worked perfectly for many trips. On my way back from Alaska I had Nav/Com 2 drop out once. It seemed there may still an issue.
On my way to Oshkosh it dropped out again, this time I was on an approach. I had the cross fill turned on so the 750 and the 355 work together. When the 355 dropped out. It corrupted all my approach way points in the 750 to user way points, dropped the altitudes and took out the airport identifier. The approach was gone! I had to reload the airport and approach all while IMC, solo and on the approach. It was so fun.....!
When I got to Oshkosh, VPX still said it is not there unit creating the issue. Garmin said they would change out the 355. At the time I said no as I felt it was not a Garmin issue. I wanted more time to test. At Osh I rewired the Nav 2 to a fuse and dropped it out of the VPX. Com 2 was still in the VPX. I had a long flight home around all the weather as I did not want to file IFR with the issue I had. It was a 11hrs of flying that day and not one issue with the change. I have been flying on and off since Osh weekly but no big trips. Not one issue until today.
Today I was on an approach just practicing and Com 2 went out. Nav2 was on as it was powered direct. Seconds later the 750 com when out, then the unit shut down. That was a first but is so bad that it led me to typing this. I can't be loosing any Nav let alone both. I broke off the approach and heading home. It dropped out 2 more times on the short 5 min flight home from there. Both radios did. That is what it did on Nav 2 before I changed the first VPX. Dropped out multiple times in a row. The radio even switched all frequencies to 121.5 which I was glad I caught before transmitting. I will be wiring the com 2 away from the VPX now just so I have one solid Nav/com.
I understand that some had issues with the VPX because of and plane power alternator. It was creating faults. Not sure I got that right. I have a new B and C so I assume that should be fine. What other test can I do to try to narrow this down if VPX is saying it is not their unit. It is really frustrating that I have went with the best of the best and spared no expense to end up have troubles that I am told no one has seen before. How can I be so lucky! I flew this plane for 15 years with breakers and never had one issue.
Any input would be greatly appreciated as I need to get this solved. Is there something that could be causing the VPX to have issues? I can't imagine trying to wire this with breakers now....
It seems that after so much time the VPX is failing for some reason no one can explain.
