yankee_echo
So I have been chasing a high oil temperature problem for the last six weeks. After swapping out every part of the oil cooling system with no success, I decided to pull the oil filter adapter and I found this when I looked inside.
I have no idea what it is or where it could have come from. It's coiled up like the shavings from a lathe and not magnetic. If it's FOD, I have no idea how it could have gotten there since nothing in that area of the engine has been removed since my oil temp problems started and if it was inside the case I don't see how it would have gotten past the screen or through the oil pump.
I'm hoping its not something in the accessory case that's about to blow up and I can't think of anything back there that would create a metal shaving shaped like that.
Engines an IO-360 with constant speed prop, magnetos and about 450 hours total time.
