My RV-9A has a cabin heat issue, that is, very little of it. I have taken apart the heat muff on the Vetterman Exhaust and examined it. Nothing wrong there, the pipes fit tight with virtually no air gap. No gaps where the two halves fit together, no holes in the scat tubes in or out. The cabin heat valve on the firewall works properly and when opened I get good air flow. At idle and taxi I get some warm air through it and some warm air while climbing, not much. Plenty of air but only some warmth. Once at cruise and lean of peak I get lots of air, but almost no warmth????
Anyone have any words of wisdom? With the two crossover pipes through that heat muff I SHOULD get plenty of heat.
Ed
Ed
