I'm going to preface this with: I have changed oil on a lot of old cars and there's always something in there. Usually looks like flakes of bearing material. I have no idea what is the norm for air-cooled airplane engines with presumably mile-wide bearing tolerances compared to your typical old Mazda.
I changed oil at 50h last time and found some trace metal. After feeling unusual rubbing/noise/resistance to the prop turning by hand after a flight this week, I was on high alert for an internal engine problem. After the engine cooled (a few days later), there is no rubbing/resistance and it turns quite smoothly. It's been about 18h hobbs since my last oil change and I forgot to look at the tach reading. Call it 15 tach since the last oil/filter change. I pulled and cut the filter to see if there were any major red flags, but I don't know what to think of these findings. Note that nothing seems to be ferromagnetic after a cursory swipe of a few pleats with a strong magnet.
This is an IO-360 A2B, overhauled in 2018 with about 260 SMOH. CHTs are always pretty cool ~300 degrees, but #2 and #3 run 20-30 degrees warmer. The engine runs smoothly and produces good power. After cutting the filter, most of the pleats look like this:
EDIT: I did not pull the suction screen this time. Last time (~15 tach hours ago) it had almost nothing in it. A little bit of rubber, probably debris I kicked loose in changing the valve cover gaskets.
