What's going on at The Aero Garage (Vendor Introduction and Updates)
Tdeman
Advertiser
Hello VAF,
My name is Taylor, and I'm the owner/operator of the Aero Garage; a small company devoted to designing and manufacturing aftermarket components for experimental aircraft. I spent 7 years on the engineering team at Van's Aircraft during which time I designed, manufactured, and tested hundreds of components and tools for everything from the RV-3 to the RV-15. Nearly every machined part on the RV-15 came out of the Haas mill in my garage, and the ones too big to run at home I went in and machined on the larger factory machines. In August, when new-management decided to eliminate all remote work, I opted to dive into my "side hustle" full time.
I currently fly/own an RV-4 that I co-built with the help of some amazing colleagues. Having used a composite MT prop, I have since developed an obsession with weight reduction; particularly at the tail of the aircraft.
One of the first products I developed and just recently launched, Lite Links (below), are inspired by the previous Tail Lynx. However, I redesigned them to utilize a titanium body, titanium tongue and tang. I also reconfigured the spring to use a considerably lighter weight spring, while still delivering an appropriate spring rate. Furthermore, each end gets a bronze clamp-up bushing and brass capture washers which the eye and tongue pivot on, for smooth motion with tight fasteners at each end. The total installed weight, is just 120 grams (4.2 oz) per pair, less than half the weight of anything else I've found available. (Factory chains and springs are 260 grams).
With over 100 hours of flight test, and 250 takeoffs/landings, Lite Links are available now and will start shipping next week. I'm running an introductory/holiday sale through the weekend on https://www.aero-garage.com/store
To all the early-adopters who've already ordered after seeing them in the "Tail Lynx" thread, I thank you sincerely, and am excited to get these into your hands.
Now that you've seen what's out, I'd like to share a product that's currently in testing... The Lite Fork.
The fork is machined from a single piece of billet aluminum on the 5 axis CNC mill. In the next machine over, the steerer spindle is turned and milled from titanium bar. And of course, a custom hollow titanium axle has been designed to perfectly fit the assembly, offering easy grabbing for a pin-style tow bar.
There's already half a dozen tailwheel forks out there, so what sets the Lite Fork apart?
Lightweight: 6.7 oz with axle (10 oz lighter than a standard Van's TW Fork assembly)
Lower profile: Designed to perfectly fit a lightweight DJM tailwheel, there is no extra width that needs to be shimmed with washers or spacers. In fact, the inside of the fork has a machined boss on each side for clean bearing contact, eliminating the need to try and slide washers into the cracks.
Better rudder clearance: The typical top stud, jam nut, and washer were omitted in favor of a low profile titanium top cap, saving 1/2" of vertical room. For airplanes equipped with titanium tails prings, this significantly reduces the chance of damaging your rudder fairing.
Static and dynamic testing are under way, as well as wear-surface material/treatment comparison. Production forks will be anodized in a variety of colors, and shared in this forum post when ready.
I look forward to meeting more of you, and revealing the next several components under development at The Aero Garage. Most updates/new products/sales will be announced in this thread, so subscribe to stay in the loop. You can also sign up for updates on the site, at:
-Taylor
That fork looks awesome Taylor!! I’m wondering how the CG is going to work out on the Rocket…..built then again, it might work really well on any of our three RV’s….Hmmmm…….
Welcome to the business!
Paul
This is really good news!
Since the original ones that I bought from Van's several years ago were available and currently off the airplane (which is still under construction) I weighed them. They have been adjusted and installed. Their weight is 194.1 grams for the pair.
Thank you Axel and Scott both for the positive remarks. I feel fortunate to have had both of your mentorships.
Paul
Thanks Paul! I'll try to get some parts in your hands as soon as they're ready!
For the international folks, the site is currently set up for US and Canadian orders. Please bear with me over the next couple weeks as I set up additional locations.
... Their weight is 194.1 grams for the pair.
Thanks for the numbers David!
Here's a side by side with an original Tail Lynx on my hangar neighbor's 6. Clearly less massive, not to mention the Ti Components are thinner, and 60% the density of stainless.
I did inquire about getting custom Ti springs made as well to chase additional grams... However setup fees in the 5-figure range shut down that idea!
Sign me up for one of those forks as soon as they are available! I’ve ordered two sets of your new steering links and I’m looking to make the whole back end of my RV6 Ti/Ali to shift the CG forward. Really nice work :)
Is the standard length correct for a plans-built RV7?
Yep!
Standard length will work on any taildragger RV that was built with the FSTW.
The only rv’s it won’t fit are the older 4/6 builds that used a bent-rod tail spring, which were cut and machined for a FSTW.
Thank you much, I appreciate the support! I’ll keep you posted when the forks are available.
Right after the forks I have another couple projects going which are right in line with your goals :cool:
Hi Taylor, congrats on what looks like a very nice product! Quick question - can you identify all the pieces in the box? Some are clear to me, but not all. There is a square thing with a slot, and a cylinder that I can't identify. Thanks!
The two parts you mentioned are the installation tools for getting the spring compressed while installing the tongue and tang.
The black cylinder slides over the end of the link body, and the slotted rectangle sits at the base (with the tongue going through the slot).
Squeeze each end in an arbor press, bench vise, or drill press, and when you bottom out the compression cylinder (thus compressing the spring an appropriate amount), you can pop the tang in from the side.
I’ll try to get some install photos together soon.
Also included in the box (but not shown in that photo) is two aluminum “drop spacers” which. These can be installed under the rudder horn to drop the forward attach of the Lite Link by 1/2” for better clearance of the rudder fairing. Most people (myself included) seem to just live with slight rudder contact at full deflection. However, if someone wants to protect their paint, they’ve got the option too!
Just to clarify - the tailwheel fork will slide straight into the original Vans yoke?
Looking forward to having the international shipping sorted. Looking good.
It's designed to be compatible with the existing options yes, including the OEM/Van's Yoke.
(In case you noticed the round keyhole vs square up top. That's solely because the articles in the photo are for destructive testing, and broaching titanium isn't something you do just for fun :) )
For those who have ordered Lite Links, or those just wondering what the process looks like, I have attached the installation manual to the footer of the first post in this thread. Going forward, I will try to attach all instruction manuals for Aero Garage parts there so it is in a convenient location.
Thanks!
Orders are shipping!
We hit an unexpected delay while waiting for springs from our supplier, but this has been remedied. The first 10 orders are on their way, and all remaining orders should be fulfilled in the next few days!
Thanks everyone for the patience, and I look forward to seeing some Lite Link Installations in the field.
Taylor
Hey Taylor, I think my order was #23 and have not heard from you. I understand you’re just getting everything together but just wondering on an update? Would be great to at least get an acknowledgment email or something. Start up small businesses are tough so I completely understand but just wondering if shipment is coming anytime soon. Just excited as the product looks amazing. Thanks, Scott
Hey Scott,
I anticipate having yours, (and all other existing orders) shipped this weekend. #15 went out yesterday, and now we're waiting on hardware.
I appreciate the patience as we get things moving. As you inferred, there's been some surprising hoops to jump through as we've gotten rolling. What I did not expect, is that the greatest hoop to jump through would be obtaining off-the shelf hardware and components in the volumes needed!
Initially, our spring supplier sent us 10 instead of 100 springs, then they were closed for year-end inventory for 2 weeks while I was trying to have the rest fulfilled. Meanwhile, I did not realize that the MS20668-3 cable terminals coming from aircraft spruce were only a partial shipment... It said they were coming from multiple warehouses, but as the boxes trickled in, I only received 30 total, instead of the 100 I had ordered! Apparently we cleaned them out, so I've ordered a batch from another supplier to keep things moving. I'm expecting delivery of the remaining terminals today or tomorrow, and will be able to get the still-outstanding orders on their way.
As for the items produced in-house, they're ready to go! Here's a photo of production running on the Titanium Link Bodies.
Operation 1 is to turn them (using the CNC mill spindle to hold the workpiece, with turning-tools mounted to the table).
Operation 2 puts them in the 4th axis fixture to the right (4 at a time), where they are through-drilled and slotted on the sides.
Thanks Taylor for the update! I really wasn’t worried and also understand the huge logistical endeavor that comes with starting small businesses and immediate lessons learned that come with it. Wishing you much success and hopefully you will take a few days to enjoy the holidays! Thanks for the update and great customer service.
Scott
if you are interested in weight savings check out this video about synthetic rigging used on sailboats to save weight. rudder cables come to mind.​
Hey Taylor. Thanks for posting the instructions. Just went through them and well done. Very straight forward and clear, thanks. I just have one question regarding the straight line mark for those of us who have titanium tailsprings. With my titanium tailspring, my tailwheel has a weight on wheel to weight off wheel travel of approximately 1 inch. However, I have measured the rudder horn to steering arm center hole distances in both the weight on and weight off wheel scenarios with negligible differences in measurement readings. Based on those measurements being relatively equal, is it safe to assume that no correction is needed for the straight line mark measurement as a result of the extra flex in a titanium tailspring? Thanks.
I use Dyneema in lots of applications. As strong as steel wire of the same dimension, extremely light, does not stretch, UV resistant, doesn't absorb water and super easy to splice.
...Based on those measurements being relatively equal, is it safe to assume that no correction is needed for the straight line mark measurement as a result of the extra flex in a titanium tailspring? Thanks.
I think you're spot on with that assumption. Any extra flex (most noticeable at landing) would be creating more slack, which is much less problematic than the possibility of extra flex causing over-tightening. Additionally, as you observed, there's not much geometry change from eye to eye as an RV tail stinger flexes... So I don't think you'll notice a handling difference as the CG moves aft with baggage/passengers.
And interesting thought on the Dyneema for steering links... I wonder how it'd hold up with oil, smoke oil, etc hitting it.
Thanks for the clarity Taylor. Appreciate it. I wouldn't re-engineer your steering links to accommodate Dyneema for the exact reasons you mention along with possible chafing. I have sailed boats however where the entire SS rigging holding up a 70' carbon mast was swapped out for dyneema. Massive weight advantage.
Happy New Years everyone,
I wanted to share a quick update on what’s happening at the Aero Garage.
We’re finally caught up on orders, including multiple international orders (now that the option is on the site). We’re also building up some inventory to keep on hand for quicker turn around going forward.
Additionally, the Lite Fork performed wonderfully through ground testing, and as of yesterday, has started flight testing!
I’m happy to report desirable handling characteristics, clean installation, and looks that match the performance!
An additional fork is being put through a custom built fatigue/cyclic testing machine to see how components wear in an accelerated test.
Hello all!
I'm excited to announce that Lite Forks are now in production, and available for preorder! Preordering your fork ensures you the soonest availability, and helps us know we're anodizing in the colors that you guys want!
We'll also be doing a batch of custom DJM tailwheels to match the forks, but those will be an extended lead time due to the number of manufacturing processes involved.
Thanks for the patience, and I'm excited to see you shed some tail weight in style!
The DJM and the JD Air lightweight tires look identical. Any idea if the JD Air version will fit the fork without shims?
Cheers, Sean
Cheers, Sean
They are in fact the same wheel, so they'll work!
They are also sold by Van's as the 6" lightweight tail wheel, and sold by spruce as replacement tailwheel for vans tailwheel assembly.
Hmmm.. Mr De Man, you could wind up costing me some money. I really like that fork. Any idea what the weight difference is between yours and the Bell fork? And nice RV-4 BTW :)
I measured my Bell fork at 22 ounces. So 7 ounces with an axle sounds pretty good to me!
Sounds about right.
Just weighed Bell Fork, axle bolt, two washers, castle nut, and cotter pin and I had 28 oz on my postal scale. I should have included the washer and lock nut that goes on top.
Heads up everyone, I've just added the Tow Bar Pin Adapters to the site! These are designed to convert your existing tow bar for use with the low profile hollow axle of the Lite Fork (or our OEM replacement Ti Hollow axle).
These positively lock into a hollow axle for unmatched controllability during ground-handling of your aircraft. These eliminate the need for heavy pegs or washer stack-ups to be sticking out into the wind every time you fly.
They utilize a machined aluminum body with stainless engagement pins. Installation takes only minutes, insert into your existing tow bar cups, set the spacing you'd like, and match drill for an AN3 bolt.
Check out the photos below, and add them to your Lite Fork order!
(If I see an order come through for these to accompany an already-placed LiteFork Preorder, I'll refund the shipping charge from the pin order, please just make a note to ship them together.)
Sneak Peak, the third picture shows some new Titanium goodness to be released soon :cool:
Exciting news, the first round of forks are back from anodizing! These will continue to be assembled throughout today, and be shipping next week!
I’ll have an extra few forks in each color for inventory, so if you’ve been holding out, there’s no wait for the next few orders!
Thanks everyone for the patience, and I can’t wait to see these out there. If you haven’t already ordered a set of tow bar adapter pins, now’s the time to combine shipping!
I received my BEAUTIFULLY crafted fork today! When the box arrived, my first thought was "Now why would he send me an empty box?" 😂🤣😂🤣 Amazingly light weight. Truly a piece of functional ART!! Then I finally had to put a pair of plyers on the titanium axle to keep it from floating up off of the table.........😆😆
Can't wait to see it on the tail end of SuzieQ!
Just received my API conversion fork. Very pleased with fit and weight reduction. Took 30 oz. off the tail! Well done Taylor.
Looks great! With its smaller spindle, the API replacement is about an ounce lighter than standard.
I received my BEAUTIFULLY crafted fork today! When the box arrived, my first thought was "Now why would he send me an empty box?" 😂🤣😂🤣 Amazingly light weight. Then I finally had to put a pair of plyers on the titanium axle to keep it from floating up off of the table.........😆😆
Reading the numbers is one thing, but holding the them in your hand puts the weight into real perspective!
I’m glad you guys are happy with them.
Ti all in! Stinger, lite links, fork and steering arm. The only thing lighter than this would be a Balsa tail skid! The airplane originally had a big heavy API tailwheel, barn door springs and chains and a steel stinger. Total weight loss off the furthest point aft is almost 5 pounds! Huge difference to the CG. Thanks Taylor. 👍
Looks awesome Paul.
I meant to tell you, I'd recommend swapping the rear terminal bolts (which go through the Ti steerer to stainless.)
I'll put some stainless ones in with your Ti-Down ring order when its shipping.
Thanks for the photos!
Taylor,
Any idea when you’ll have items back in stock on your website?
One thing about Dyneema worth mentioning, is that it's slippery. At higher loads, Dyneema will slither right out of knots, including stopper knots intended to prevent that. I've seen this happen during controlled pull-testing. The only thing that'll carry serious load using Dyneema, is splicing it.
Knots work fine for small loads.
Dave
Taylor,
Hey Josh, (and the rest of the community), you guys probably saw many items flipped to out of stock on the site. We're taking some time this summer to finish building our small Cabin in AK. We had just managed to dry it in last summer, but are picking up where we left off to try and finish it out. Just before we hit the road, I built up a bunch of inventory to bring with us which I've run through quicker than anticipated!
Things I do still have plenty of on hand include Ti Down Rings and Locking Jack Cups, as well as all the spare parts for Lite Links.
Fortunately, the post office is just down the road and priority mail is still seeing 3-day delivery to the lower 48.
I'm planning a trip back down to OR to restock and resupply, but that will probably be around the end of June.
I do plan to have everything available in time for Osh Kosh.
Picture below if you want to see the Aero Garage HQ for the next couple months.
Hi Taylor
Just come across this thread, was looking to order some items including the lite fork etc, will you ship to UK ?
Should I pre order ?
Chris
I have all of your stuff on my RV14 and i am very impressed with your quality. Hopefully you come out with some great ideas for my RV10.
Well done.
Thor McIlrath, KAWO
Arlington, Wa
Well done.
Thor McIlrath, KAWO
Arlington, Wa
How does one contact the company?
I have tried the contact form on the website, tried on here and never hear anything back?
