I switched back to Wix, probably doesn't make much difference to Lyc, as Bob says. However, I came to these conclusions:
- Much wear is in the start. The Challenger/K&P provides better flow, but no drainback valve. Not sure who has the advantage there, but good preheating (WI) and Lyc lubricating system probably makes it moot.
- Challenger/K&P quad rings required replacement. I reused the same one 3X and it definitely showed some wear requirement replacement. I decided to change mine with every oil change. This adds (minimally) to the cost of ownership.
- I found the Challenger/K&P no easier to clean and inspect, which was one of the main reasons for the purchase.
- I liked the form factor of the Challenger/K&P, very easy to change out limiting the likelihood of spills.
- There seem to be no mechanical drawbacks to having better filtration. Any flow restriction delta is ultimately compensated for in the Lyc lubricating system.
- Wix filters are cheap, $4.81 currently on Rock Auto...which makes the K&P less advantageous if you replace the quad ring every oil change. This takes over 60 oil changes (3000 hrs) to break even on K&P cost.
- Free market has made the decision for me. Automotive industry doesn't use reusable screens. The competitive market place eeking out every bit of longevity and reliability tells me the science has been decided. Racing teams use the K&P, but they have different goals.
