And that discussion may be something to look at, but the previously mentioned threads focus on “filter performance”. And in those terms, the Challenger and clones are demonstrably terrible.My opinion is these engines don't appreciably wear from or produce hard wear particles small enough that make any of the "tested" filters result in less wear in service than engines using the Challenger.
I fly an RV 9A with a Titan IO 360 and am thinking of switching to the Challenger reusable oil filter, anyone have any thoughts? What about using the K&P automotive version? It's almost exactly the same thing but much cheaper?
I would say they make EXCELLENT spittoons!They seem to make great coffee cups, or mini-spittunes!
Yea, I tried yelling to Mike through my phone podcast program, but he didn’t hear me.Mike Busch was singing the Challenger’s praises on his most recent podcast. I wondered if there was a way to point him to that thread.
1/4 price!!A whole bunch of us purchased one of the reusable oil filter variants awhile back. A whole bunch of us now use them as paper weights. That being said, happy to sell you a barely used one for half price if you are still interested.
I turned my K&P filter into a paper weight, but I’ll sell it to you.I fly an RV 9A with a Titan IO 360 and am thinking of switching to the Challenger reusable oil filter, anyone have any thoughts? What about using the K&P automotive version? It's almost exactly the same thing but much cheaper?
The oil analyses that were posted in that big long thread didn't show any appreciable differences between the Challengers and anything else "tested". Wear, dust, fine particles etc. don't damage aircraft engines or cause them to wear prematurely. Most aircraft engine problems stem from things that absolutely no filter will catch, like lead particles and acids in the oil.And in those terms, the Challenger and clones are demonstrably terrible.
When I read that thread, I was having similar thoughts. For example, the oil screen that Lycoming installed on my engine is courser than the challenger, and takes a lot of engines to TBO. I'm glad others feel good about there filter knowledge, for educating us. I also keep an open mind about what worked for millions of hours in the past may still be legitimate today.The oil analyses that were posted in that big long thread didn't show any appreciable differences between the Challengers and anything else "tested". Wear, dust, fine particles etc. don't damage aircraft engines or cause them to wear prematurely. Most aircraft engine problems stem from things that absolutely no filter will catch, like lead particles and acids in the oil.
Or simply the results of Dan's lab testing?It sounds like most people are dissatisfied with the Challenger filter. Is it a case of bad oil analysis, poor workmanship, or out right failure/leakage?
Again, the argument about “effective filtration” has been proven with lab testing. The Challenger sucks. Period, dot. But that is a different argument than “…does the Lycoming need good filtration?…”The oil analyses that were posted in that big long thread didn't show any appreciable differences between the Challengers and anything else "tested". Wear, dust, fine particles etc. don't damage aircraft engines or cause them to wear prematurely. Most aircraft engine problems stem from things that absolutely no filter will catch, like lead particles and acids in the oil.
Lycomings with 0.006" piston clearance doesn't need filtration literally down to the uM level of bacteria. The lab testing did not prove any increase in longevity of a typical Lycoming and it cannot be inferred from that test.Again, the argument about “effective filtration” has been proven with lab testing. The Challenger sucks. Period, dot. But that is a different argument than “…does the Lycoming need good filtration?…”
I went thru that exercise with multiple tests and comparing the oil analysis after using Challenger, Champion and synthetic automotive filter which independent test facility had shown to be the best. My oil test were all just about the same using the three oil filters. This test was done with two airplanes and both showed the same result so I have put my challenger back on.The oil analyses that were posted in that big long thread didn't show any appreciable differences between the Challengers and anything else "tested". Wear, dust, fine particles etc. don't damage aircraft engines or cause them to wear prematurely. Most aircraft engine problems stem from things that absolutely no filter will catch, like lead particles and acids in the oil.
lycoming’s tolerance for dirty oil before it does damage is a test that will likely never be performed. Nor should it - it’s like trying to figure out how high a brick needs to fall before it hurts your head when you can just wear a helmet.Lycomings with 0.006" piston clearance doesn't need filtration literally down to the uM level of bacteria. The lab testing did not prove any increase in longevity of a typical Lycoming and it cannot be inferred from that test.
The discussion is happening because screen filters like the Challenger are being poo-pooed with unsubstantiated reasoning. They are good enough for Lycomings and they're much easier to deal with when it comes to inspecting. Dare I say they're more environmentally friendly to boot. Saying the other filters work better in the real world is a stretch of the imagination as I continue to point out here. There is zero data to support that conclusion.Do we need to clean oil down to the molecular level to keep a Lycoming alive? Clearly not. But when one can choose a paper filter that is cheaper, lighter, more available, more reliable, and wildly more effective than the Challenger, why is this discussion even taking place?
Exactly my point. They work fine. Anyone that says they should be used as a spitter, coffee cup, etc. in my opinion should be walking around the grocery store with an N95 mask on so I can laugh at you.This test was done with two airplanes and both showed the same result so I have put my challenger back on.
Cleanable mesh filters are widely used on turbine engines like the PT6 yet people here hyperventilate using a Challenger filter.
Along these lines, I had the old fashion screen on my RV6. After 1500 hours, it told me that me engine needed serious attention. I found one piston was starting to burn through.The oil analyses that were posted in that big long thread didn't show any appreciable differences between the Challengers and anything else "tested". Wear, dust, fine particles etc. don't damage aircraft engines or cause them to wear prematurely. Most aircraft engine problems stem from things that absolutely no filter will catch, like lead particles and acids in the oil.
Oil analysis that folks have done with and without these filters in use proves otherwise.Data is a calm illumination, and it says the reusables are poor filters.
The Challenger filter is poo-pooed because they are deficient as filtration devices compared to almost every other filtration scheme. This has been established with hard data. They SUCK. That’s all many people need to know. Whether that poor filtration translates to lower component life or safety is wide open for debate. But one thing that is NOT in question is that cleaner oil is ALWAYS better than less clean.The discussion is happening because screen filters like the Challenger are being poo-pooed with unsubstantiated reasoning.
Please take a moment to dig deep in your mind and explain why oil analysis doesn't reflect this. Using perjoritives just further indicates to me you are grasping at straws.This has been established with hard data. They SUCK. That’s all many people need to know.
I don't think anyone can deny test results. I think the debate is whether better filter is necessary.Do you deny the results of the particulate removal performance published in the other thread?
Exactly the point of my first sentence in my first post in this thread (post #5)I don't think anyone can deny test results. I think the debate is whether better filter is necessary.
Not at all. But, like I've said, the filter lab tests prove not a single thing about realty.Do you deny the results of the particulate removal performance published in the other thread?
Aside from all the good rehashed information, I think it boils down to this.
1- OP didn't search CHALLENGER before asking
2- Lycomings don't need a filter, if you're just wanting to catch what Lycoming's oil mesh has always caught
3- The Challenger does a worse job at filtering than the $10 disposable WIX and others cheaper than the Challenger
4- Keep doing oil analysis testing every oil change because that tells you more than any filter
5- If you have a Challenger it doesn't hurt to use since you already paid for it and it's easier to inspect it than a disposable filter
and finally
6- If you DON'T have a Challenger but decide you want to pay so much for something that catches the same thing the original oil mesh does, instead of using a cheaper disposable filter, and later come complain about the price of eggs, someone will so a search and flame you for it later![]()
And I think the issue here is that you are unable to compartmentalize two distinct concepts. One is the fact (yes, I said “fact”) that the automotive style cellulose filter is superior to the screen at pulling junk out of the oil. That FACT is compelling when trying to decide what method you want to use. Cheap and effective wins over costly and ineffective in my book.…Or I should say I think I know the reason, and that is you don't want to admit that your reasoning is flawed…
I sent Mike an email with a link to our forum thread with the filter results. We’ll see if he addresses the filter suitability again in a future podcast.That's not quite true. He said it was an experiment, and he was not ready to write any articles about them. He has only done one oil change, and although he pointed out all the usual practical advantages, neither he or his co-hosts addressed filtration.
I believe, it's not about the piston clearance but about wear and tear on bearings.Lycomings with 0.006" piston clearance doesn't need filtration literally down to the uM level of bacteria. The lab testing did not prove any increase in longevity of a typical Lycoming and it cannot be inferred from that test.
Good point. Agree.I think the mods could probably close this discussion. The original question has long since been answered, and the rest of the discussion isn't any different than the discussion in the original filter testing thread.
Sliding contact suffers far worse abuse from particulate including water e.g. gear teeth, cams/followers, etc.I believe, it's not about the piston clearance but about wear and tear on bearings.
We seem to have just about run this thread into the ground, but as a follow-up, here is Mike Busch’s response to my email to him regarding the lab testing results on the various oil filters:That's not quite true. He said it was an experiment, and he was not ready to write any articles about them. He has only done one oil change, and although he pointed out all the usual practical advantages, neither he or his co-hosts addressed filtration. He was totally wrong about the construction of the Challenger media ("laser cut holes"...nope), and pressure loss across the filter.
I was amused when he started talking about how much smaller they were. Yep, there's a reason for that....
This topic is like so many of the things going on in this world today. I simply do not understand "the other side". I don't know if it's because I'm getting old or if things really are weird…
