Show us your RV-10 Panel
Hi Martin,
Hi Derek,
thanks for the nice write-up. I love this group. Every plane is a bit different and what you did makes perfect sense.
You can question this decision but my engine depends on electricity. If I can cover one more remote case that would help, I'll not pass on that option.
I am putting in two EarthX batteries that can deliver a lot of current and they have all sorts of internal supervision and if something is violated, they shut off. I am therefore afraid of activating the cross bar / bus tie should one battery be low and the other full. The last thing I want to do is tripping the good battery by switching the bad one in parallel. Anyway, that was my thinking, I want to turn one battery off before activating the cross bar but I may want to use the alternator of that side. Just a very remote case.
Thanks for sharing your overvoltage thoughts, very helpful, I'll check that on my side.
/Martin
Hi Martin,
Not questioning the decision at all, in my mind both are valid solutions and widely used. Keeping the engine running makes a difference.
The bus tie issue is a real one for sure, and worthy of a placard. I haven't settled on the wording, but it is certainly one I want any pilot to be aware of, and not one I had thought of until reading the earthX manual. You really should not be connecting the two batteries together in flight. 99% of the time it will work fine, and its great to have the ability for starting, but I sure would hate to be in the situation of having one dead battery, one good - tie them together and have the good one decide it was dead shorted, or put more energy into the dead one than it could absorb. Lots that can go wrong in that scenario. No issue if you turn off one battery when you connect the buses, or if both are at similar voltages. (EarthX specifies 0.3V)
For those not aware, the issue is that since the LiPO (and really all batteries) can put out and receive a bunch of current due to the low internal resistance, connecting two batteries in parallel that have very different charge levels will flow a bunch of current into the one with less power, and you don't want to do that.
So if you have them in parallel you want to either keep them connected most of the time, or keep them separate. In my case I opted for separate, since I seem to have a statistical propensity to the overvoltage failure case.
Hi Igor,
very impressive panel. I love your panel lights. Who is producing them?
I know you are installing AT-1 for traffic awareness. But which transponder device are using then?
Alex
Hi Alex, we make these push buttons and annunciators in house. PM me if you are interested. They are made in Germany and we modify them with custom text + the text is readable only when the LED is lit. So you have a nice airliner style 'dark cockpit philosophy'.
I'm using the GTX35R transponder. The AT-1 is wired to the G3X and GTN. One dedicated 'Traffic Mute' button is on the panel and the 'Traffic Acknowledge' button is located on the stick.
thanks,
RV10 Panel Upgrade
After 1300 hours and almost 10 years, I finally decided it was time to move this panel into the future. Below are the "as built" photo and the newly upgraded photo. With the exception of the power system, this required a totally new harness. I'm looking forward to another 10 years of flying behind this great panel!
The new panel definitely looks a lot nicer than the late 60's panel that you had! :D
But seriously, very nice!!!
Looks awesome Bill!
Great minds think alike… :)
Just got mine from SteinAir. It is a beauty! Putting it in will require quite a bit of disassembly and reassembly, so enjoy it now before I mess it up.
Mine arrived today
Aerotronics did my panel. A thing of beauty.
I'm going to watch progress on this one. I'll probably go for the remote audio panel and won't have a/c and O2. Otherwise this is pretty much the setup I'm aiming for.
Major parts working after running some 138 wires (see https://docs.google.com/spreadsheets/d/1AqWwhWavieX5wUc94eRBboVtdiVnk19nisR-6vLuD6g/edit?usp=sharing). I have a 650 main GPS and a 375 secondary GPS with transponder. Cross fill works via the G3X system.
I built the sub-panel and center rib out of wood to be able to mount all the boxes in their designated places to get the harness right. I printed the sub-panel and rib at 1:1 scale at a Fedex Office place ($1 per square foot), then glued it to the wood panel and cut it out.
Beautiful setup!
Xometry
I would like to share about my experience with ordering an aluminum panel through Xometry. They have charged me around 300$ inculding a delivery fee from Mexico.
So, I just uploaded my STEP file of the panel, clicked the button Order and in 3 weeks later I received a panel. It was very easy. I really like the quality of their laser cutting and tolerance. All the holes on the panel have been designed with the tolerance +0.2 mm to the actual diameter of the switches, LEDs (every single item was measured with a caliper during engineering process... Don't TRUST the drawings provided by manufactures!!! ) And the actual diameters on the panel I received are exactly +0.3 mm
F1
F2
F3
IMG_8972
IMG_8962
IMG_8961
IMG_8973
Tim,
Nice work! Any chance you are willing to share your STEP file? Would make a great starting point for those of us looking to do a G3X. It looks like you've already gone through the trouble of sourcing the individual models, etc
I'm waffling between an Aerosport panel or a traditional panel. Would be fun to experiment and move things around.
David
Files
It's not the end. I haven't even started a bottom console, where I am going to place all other switches, engine controls.... etc.
It's just the base aluminum panel. And I am also going to attach a fiber carbon overlay panel. The reason I personally don't like Aerosport's panel - they look like old Toyota's dashboard and it's not possible to fit as many instruments.
I would love to share everything I have, but I don't know how to share a 150 mB file here.... The project has been made in Autodesk Inventor 2023, so I can make a ZIP archive or export it into single STEP file
Let me try the Google drive...
https://drive.google.com/file/d/1iXm1BkdXypiLO0dJyfUC23RsLNx3Z69F/view?usp=share_link
Let me know if it doesn't work
It's just the base aluminum panel. And I am also going to use a fiber carbon overlay panel. The reason I personally don't like Aerosport's panel - they look like old Toyota dashboard and it's not possible to fit as many instruments.
Let me try google drive...
Thanks Tim! A STEP file is a fairly common format that can be imported into a number of CAD programs. Question is whether or not it will maintain object groupings etc.
Google Drive works great if you get the share settings right.
Basic Panel
We are doing a basic panel - HDX, knobs, Garmin175, PDA360, G5 and iPad.
So, who has split their panel for access on a std fit ?
Where and how do you do the sub structure ?
Only rack items are the audio and Garmin.
Was thinking of a 1.5" wide .063" spreader that can accept nutplates.
Aerosport Symetrical Panel
Left, Middle and Right pics after 200 Hrs. Just removed a label for the E-Mags and milled a nice plate for the mag switches.
Regards,
Dozer. Since you are using a laser cutting service you have the option of having them leave a tooth inside the switch and breaker holes for indexing and keeping them from moving. I even do it when there is a keyed magneto switch. So no extra switch locking holes or indexing washers are needed for the components. Attached is an example of the hole configuration I am talking about. I have these laser cut and it works out really well. I do have to do a little bit of slag clean up with a small file but it only takes a few seconds. Both methods (holes or indexing teeth) yield very professional results.
I like a hole for a washer with a pin. But if someone really need to have a tooth, make it bigger and then file it to specific size. Laser unable to do very small teeth (they are melting at the tip).
But the reason I like those extra locking holes - my panel is a sandwich (aluminum base + fiber carbon overlay). And I don't make locking holes in the carbon fiber panel.
Not the best pic but you get the idea.
Dual Dynon HDX 1100, Dynon Comms (2), Garmin GPS 175, Garmin 340 Audio Panel. Not shown on left side...E-Mag dual electronic ignition switches.
I have no VHF nav radios. The Garmin GPS-175 gets me around in IFR. I've flown a few flights in IFR weather and have never missed that VHF Nav capability.
Thinking about attending Airventure for the first time in fifteen years to celebrate Rv10 anniversary
Aerosport symmetrical panel, all Garmin, remote com 2 behind luggage bulkhead.
2 E-Mags. Last pic I moved the AP head down where glove box was. Can fly right/left seat wo issue to panel layout. VPX Pro for circuitry.
My backlit panel from Midwest Panel Builders
Ordered it in October 22
Received on October 16,2023
Received excellent documentation, with clear cut drawings and instructions
Proper labels on all terminals
Templets for cut outs
We had some doubts, so Steve and Adam personally flew down and helped in mounting
I am amazed at seeing what goes behind beautiful looking panel
It’s like Human Nervous system, well laid and complex
When I am typing this, I can imagine the electrical impulses traveling to and from my brain, making it possible. Similarly the meticulous work behind those big, beautiful Garmin screen, makes it work flawlessly
Await final picture
Will post the final review after flight testing
Here you can see me with my very efficient A&P Abbey, Steve and Adam
Await final picture
Let's not let Dan see that inside firewall covering :) Perhaps rightfully so.
but congrats on a beautiful panel.
I have used soundex insulation to dampen noise and vibrations in cabin, and sound dampening pain in tail
New Panel
Saint Aviation did a great job in upgrading my Skyview HDX panel. Removed the VP-200 and we replaced it with the Advanced Flight Systems - Advanced Control Module. New panel has worked flawlessly.
Added:
AV30E
7" Skyview
2nd ADHRS
Dynon Com Panel
New USB plugs
Lots of new Advanced Flight switches
Blank panel and all plug and play cables/configuration for new 10" Skyview (when I find some money)
Moved everything from lower panel to main panel
They cut the new panel, power coated it to the color of my choosing and then engraved everything...first class all the way.
Removed:
Gemini ADI
TruTrak B/U Battery
Garmin GL106A
Vertical card compass
Dynon SV-ARINC 429
Icom A200 Com
Lots of serviceable VP-200 parts available if anyone is interested.
First pic will be the old panel with the VP-200 and the next three will be the new panel.
I couldn't be more pleased with the upgrade pricing and in the work that Jesse and his crew accomplished in only 5 weeks.
After 15 years of flying I upgraded my panel. Thanks to Steinair for all their help. I stripped everything out and also added the over head air. All the extra work was as much work as the panel itself. It’s like a brand new plane. This was my winter project and spent about 700 hrs doing it.
Here's mine. I'm pretty proud of how it turned out, especially the backlighting. Makes the night stuff a lot easier.
Been wiring for what seems like forever but finally have something to show. I tested out the panel on the bench in late December and been running wires behind the panel and to the tail since then. I spent more time than I should have on the backlit panels but they came out real nice. The outside layer is 1/16 inch black on white laser etched acrylic (from Stryker) over a 3/16 inch 3D printed spacer that has slots in it for LED strips. Most of the available LED strips are in 1 inch increments but I found some 0.5 inch strips on Amazon that made it possible as the 1 inch strips would have been too wide in some places. In between the LEDs and the acrylic, there is a blue gel filter to remove the yellow tint from the LEDs so the text matches the Garmin white. I'm running the LEDs at 3.0 V to improve the life (and they're still plenty bright at max brightness) so I added a small linear regulator to run them off of bus power, then use the GAD 27 PWM output to dim them. I'm going to have to work on the discrete LEDs on the power panel, they're way too bright. I picked some really bright ones in hopes of being able to see them during direct sunlight but the GAD 27 won't dim them enough, even at the lowest setting. The headphone jacks haven't been placed yet because I changed my mind where I was going to put them and now there's not a good place. I may put them near those U-channels on the sides. The footwell lights (visible under the panel) are 12 V LED strips, also dimmed by the GAD 27. The panel is Cerakoted so I still need to attach the nameplate and experimental placard. I'm waiting to finish the firewall forward wiring and then I'll tie up the wires behind the panel and post a pic of that. The important circuit breakers are on the front but there is another auxiliary circuit breaker panel under the MFD just to the right of the GTX 45R that is sticking down a bit. I only put breakers on that aux panel that support devices that can be checked during preflight such as the lights, etc.All the stuff dangling down (air data tubes, audio wiring, PFD/MFD/G5 GPS antennas are still in work).
-Bob
The center rib is always an issue for RV-10 panel design. I start with the goals of:
- Each EFIS display is as high as possible.
- The GTN-650 is in between the displays, but also as high as possible (don’t want to have my eyed pointed down to manipulate it when ATC give me yet another reroute).
- I stay with the stock aluminum panel and lower panel apron. My experience is I should assume I’ll rework the panel at some point, so keeping the stock piece of aluminum makes this much easier, and cheaper.
- The panel is fully removable in a few minutes. The apron stays on as it does not contain any avionics. The apron provides mounting for all the switches, breakers and control cables not associated with the panel (or panel avionics like the displays that have a D connector to allow for panel removal)
A buddy made me a GTN-650 mockup to figure out how to modify the central rib. This made life a lot easier. The center rib is trimed at the height of where it goes through the next forward bulkhead. The trim section is reinfforce with a doubler made of 1/8” aluminum. The result is the practical highest the top of the GTN-650 can go is 5” below the top skin.
On the first RV-10 I biased the GTN-650 to go on the left side of the center rib. This worked but forced the left EFIS display left, so the panel curve forced the top of the left display lower than it could be.
Side note. I replaced the panel in the first RV-10 at 18 months. Too many “good” ideas that proved to be not so good. The plane is now 12 years old and the new owner did another panel redo last year (updated SkyView to HDX, G5, etc.). A new piece of aluminum, time cutting holes and some paint - done.
Final bulkhead hole size will be determined later (to allow for cable runs and such). Once done the hole will be reinforced with 0.063” 3/4” x 3/4” angle.
Now on to figuring out where all the remote boxes go. No - none will be forward of this bulkhead between the panel and the firewall to meet the other design goal of “never on your back with your head under the panel”.
I need to take some better pics but here are the before and after. My father built the plane and originally installed a Chelton EFIS and a VP-400. By the time he received an AW certificate (at 80 years old) but before ever flying the airplane, he decided he didn't want a panel with so many orphaned components. So, he tore it all apart. Unfortunately, he never got a new panel installed before he passed away three and a half years ago.
It's been a long journey but this week, I made the first flight in N420LK! It was emotional and exhilarating and it wouldn't have happened without the help of some amazing people. Thank you! (you know who you are - NR, JC, DM, among others.)
Battery and IBBS Switches
Joe,
Love the organization on your panel. Why did you choose rotary switches instead of toggles for battery and ibbs?
Bob
It has to do with total integration. I wanted engine control switches (mags, boost pump, start arm) grouped with the other engine controls (throttle, prop, mixture). The section of the console I used is near the GTN. In order to keep switches from getting in the way I chose the rotary switches. The electrical control switches followed suit for consistency. I've flown them for 600 hours now and really like them. They also help clean up modernize the look.
Joe,
Also wondering what carbon fiber material you used? I’m planning the stock because I like more open space for the legs.
Sumit
The material is a 3M Dynoc wrap. Local trophy shop was able to etch the labels into the material. Mask-laser cut-colorize-remove mask. If a mistake is made just remove the wrap and redo. The lasser only cuts through the vinyl, not the aluminum.
Amazing thanks. Didn’t even think to ask on the labelling technique. You’ve got an eye for a clean symmetrical panel which is how I’m planning things as I build my panel now. Helps tremendously with cockpit mgmt in IFR IMO. One aspect of my SR20 I want to maintain.
Agree with the IFR mgmt comment. I can't claim too much originality. I've stared at large military, airline and corporate panels for many years. Compared panels designed in the 60's to modern ones. Tried to incorporate features that the professional engineers adapted. Most notably: controls (including switches and knobs) grouped physically and visually by system (engine, fuel, electrical, environmental, lighting, autopilot, etc), use of automation to declutter (remote avionics, minimize switches), ergonomic placement considering eye position and hand movement during critical tasks, electrical system design to remove the clutter of c/b's (fault tolerant system and operating philosophy = remote fuses that are not replaced during flight was my choice).
Great to know some of the design decisions of the pros line up with thoughts I've had, without diligently doing the research as you have. Planning a number of things you point out.
Minimization/automation/decluttering/controls: dual g3x touch, gtn 650xi nav/com 1, remote nav/com 2, remote xpndr gtx45r, remote audio panel gma245r, gmc 507, g5. My only physical switches are bat 1, alt 1, and alt 2 masters, boost pump beside throttle, and an ACS keyed ignition switch for the emag/mag/start. Lights, cabin climate controls, and pitot heat switches are getting put on a Nextion touchscreen with page groupings, feeding ground enabled switch inputs to the VP-X, GAD27 and flyLEDs, backed up by on-PFD control of the VP-X switching, with the VP-X itself backed up by VP-X backup method B for the essentials.
Ergonomics/eye hand movements: g3x pfd and mfd are positioned side by side on the pilot side. Touchscreen, GTN and autopilot controller below those in a horizontal configuration, working to mimic the G2000. Audio panel, transponder and nav/com tuning on the PFD/MFD, autopilot on the GMC, flight plan editing on the GTN. I might give more thought towards how you've placed your mag switches very close to throttle, which has value on doing flow work on abnormal and emergency checklists.
Electrical system: Leveraging the VP-X with dual battery and dual alternator. All of the essentials can be powered by one or both of the alternators or one or both of the batteries. With our without the VP-X in the loop using backup method B that backs up the VP-X electronic circuit breakers with fuses off the batteries.
