This is my first post to the VAF Forums. I'm looking for help and info on installing an AntiSplat Aero Oil Cooler Shutter; and, I would appreciate any guidance that you may be able to give me..
I have an RV-7 with a Mattituck IO-360 that has the Oil cooler at the rear baffle wall by the #4 cylinder. I also purchased a push-pull cable so that I can control the adjustable openings on the Oil cooler shutter. I live in NW NJ and I fly at least once a week since it is good for the engine (and, even better for me !!). But, Winter flying makes it hard to get my Oil Temp above 160F. I have been using foil tape to cover the Oil cooler; but that requires taking off the cowling before each flight to adjust the foil tape depending on the anticipated OAT.
Hope that you can help,
Thank you, OldNavy
Thank you, OldNavy
