Old 02-07-2021, 01:01 PM
rockitdoc's Avatar
rockitdoc rockitdoc is offline
Default Panel Mocked Up
Painted the sub panel last night. First mock up of panel with model avionics. I hope everything fits between the panel and the sub panel.
We'll see.
Click image for larger version
Name:	Panel Mockup.jpg
ID:	8062  Click image for larger version
Name:	Panel Mockup Behind.jpg
14A
Begun 07-23-20
Emp Completed 11-12-20
Slo Fuse Completed 3-2-21
Wiring and Avionics Begun 3-3-21
QB Wings delayed until ?
Finish Kit expected 7-21
Thunderbolt EXP119 expected 7-21
2021 Dues Paid
Reserved: N52XL
Old 02-08-2021, 07:37 AM
esco esco is offline
Default 3D modeling
Originally Posted by rockitdoc View Post
...First mock up of panel with model avionics. I hope everything fits between the panel and the sub panel...
Nice models. Foamboard?
______
VAF dues paid though exempt
RV-9A sold (I miss that bird!)
RV10 sold (miss that one too!)
RV-14A build underway
Old 03-25-2021, 06:13 AM
rockitdoc's Avatar
Yes. 3/16” from the Michael’s aircraft section of the store. Hot glue works great.
14A
Begun 07-23-20
2021 Dues Paid
Reserved: N52XL
Old 03-30-2021, 09:26 AM
rockitdoc's Avatar
Default "Finally" Decided on Panel
Quotes are obligatory, of course.
Anyway, I've decided to stick with a split Master/Alt switch, conventional Ignition with L/R/Both/Start and two Pmag switches to test the Pmags. Since Dynon says avionics can be on during start, the avionics switch is next to the Master/Alt.
I Think I will gang the nav/strobes on one DPDT switch and the taxi/landing on one, as well. Then the flaps and fuel boost pump will be over by the engine controls. Two USB and the ELT will be on the right by the copilot EFIS.
Oh, and the primary EFIS will probably move a bit to the right to give a bit more room for the five switches on the left.
Name:	PAnel Mockup 3-30-21.jpg
14A
Begun 07-23-20
2021 Dues Paid
Reserved: N52XL
Old 04-07-2021, 10:53 AM
rockitdoc's Avatar
Default Changed My Mind.....AGAIN!
So, I 'think' I have decided to simplify the switches instead of ganging multiple functions into single switches. Originally, I was thinking fewer switches would be better on the front, but now, I think I would prefer individual switches for specific functions.
This means taking up more space on the front, but there is room to do it. So, I think it will make it easier for me to remember what each switch does.
The logic, so far, is that start up operations are clustered on the far left, when my left hand is not occupied with the stick. Lights, fuel pump and flaps are on the right above throttle, mixture and prop when my left is busy with the stick.
Anyway, take a look and give me your thoughts on how manageable you think this is. I appreciate your opinions since most of you have WAY more experience than I do.
Name:	PAnel Mockup Switches 4-7-21.jpg
14A
Begun 07-23-20
2021 Dues Paid
Reserved: N52XL
Old 04-07-2021, 10:31 PM
n982sx n982sx is offline
I would combine the master and alt into one three position switch. Off - Batt - Alt & Batt.
I prefer no Avionics switch but my system prevents brown outs which is a problem for some setups.
I turn on power as soon as I get in the airplane which means that all the avionics power on and stay on until after engine shutdown.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 04-16-2021, 07:59 AM
rockitdoc's Avatar
Default From Foam to First Metal
I mounted the avionics in the center panel yesterday after one glitch that cost me a day. The Dynon template for the Intercom Panel is too large so the unit was closer to the Com Panel than the other avionics. Oh well, the second try only took 4 hrs.
Fabricated my own canopy jettison handle because I wanted it centered on the panel instead of off to the starboard side. Also, made it smaller to take up less room and make it harder to pull in error by a curious passenger. It's also labeled 'Passenger Ejection Seat' to discourage accidental deployment.
Moved USB slots to pilot side and still need a switch for panel lights.
Question, though:
What are folks putting in the two holes below the throttle, prop and mixture? Alt air comes to mind. What about the other one?
Name:	Panel Center with Instruments Centered.jpg
14A
Begun 07-23-20
2021 Dues Paid
Reserved: N52XL
Old 04-16-2021, 09:31 AM
JHartline JHartline is offline
One is for Alternate Air and I believe the other is for the cowl exit flap.
Question, though:
James Hartline
Carrollton, GA 5GA2
RV-14 - First flight 4/7/2019. Phase I complete as of 9/11/2019!!
Old 04-16-2021, 11:17 AM
Kedy.va Kedy.va is offline
working with the panel
Old Yesterday, 03:23 PM
rockitdoc's Avatar
That makes sense. The IO390EXP119 has cowl flaps.
14A
Begun 07-23-20
2021 Dues Paid
Reserved: N52XL
