The VAF News - 8.25.2025. #6380.
DeltaRomeo
doug reeves: unfluencer
Staff member
dr
Bravo, sir. Bravo!
I use discarded plastic medicine bottles. Each has a label of where on the aircraft the screws came from. Prior to reinstalling the screws, I look at each one and decide if it needs to be replaced with a new one.
Iron
Clayvt
Daily
…Vlad
flywithayres RV-10
mburch
jackking123 RE Panel Planning
Hangar 1271
RE Wheel Pants Flat Head Screws
…dmattmul
8-32 by 1/2 on the brackets, typically 6-32 100 deg on the shell half's but that depends on nutplates used. Torx, hex or No 2 Phillips. Is that what your question is? Also, your plans from Vans Aircraft should specify.
OFF TOPIC:
