The VAF News - 12.04.2024. #6228. What did the buffalo say when his son left for college? Bison.
DeltaRomeo
doug reeves: unfluencer
Staff member
Webb
Richard Connell
…oil cooler bracket crack update
I should have added to my original post that my 7 did the same thing at around 200h back in 2011.
Here’s the replacement: 1/8 angle plus an extra tie piece. I also installed a diagonal brace from the forward edge of the #4 cylinder to the inboard edge of the oil cooler mount.
My memory is stretching for this but I also seem to remember that that particular baffle piece was or should have been 6061 not 2024.
Scott Hersha
…bent stick PIREP
I did that a couple times on my RV8’s. I made a jig to hold the parts while tack welding (see pic). The opposite side of the board is similar so I could tack both sides before welding. I cut a 3” piece out of the stick on 60* angles, rotated that piece 180*, and welded it back in place. It worked well for me and cleared the seat bottom.
Then on my RV4 (later in life), I used an RV14 stick attached to the cut off RV4 stick. The RV4 stick is the same as the RV8. I had to machine down a section of 4130 tube to put inside the cut off RV4 stick because the fit was a little loose.
Baffle Mod Question
…supik
What is your opinion on using a brush seal in the slotted area bottom cowl? The brush seal has nylon brushes (should be good up to 250 F)
Classified Spotlight
OFF TOPIC:
