The VAF News - 11.13.2024. #6213. RV Hotel, Sumps, Unlatched Canopy, Senders, Oil Cooler, 10K Pot, Step Wobble, Stud
DeltaRomeo
doug reeves: unfluencer
Staff member
RV Hotel Updated
…in the VAF List
RE Bridge between Sump Bosses
https://vansairforce.net/threads/left-side-throttle-on-io360-a1a.230949/post-1804032
Unlatched Canopy PIREP …seagull RV-12
Just to add some more info for anyone scared of an unlatched canopy on a -12. Today I was ferrying a -12 for the new owner. It had a 180 panel that is set up differently from my “touch” panel. The audio warnings and warning lights are setup differently, enough of the excuses. We took off and were in the crosswind when the owner felt a breeze and looked up to see the latch had not been engaged. He called it to my attention and I grabbed the handle. The canopy never tried to open past a crack, maybe 1/2”. I lifted it a bit and it easily went up but not aggressive. I handed off the handle to him and continued to fly the plane while he was able to secure the latch. It was a non-incident.
https://vansairforce.net/threads/results-of-opening-the-canopy-in-flight.191312/post-1804030
RE Senders Grounding Pic …Cth6
Here is a pic of how I ensured my senders were properly grounded to the firewall side of the ground bus. That is a zip tie holding the connector to the sender body. I have since upgraded to an EI CGR-30P, but this got rid of random fluctuations for me.
RE Oil Cooler Pic Request …flysrv10
Brian Decker requested the attached pics of my installation.
RE 10K POT source
…benglish
I really like the Vishay / Sfernice P16 pots. They are very lightweight and are working well for the since 35 hours since install. There were several options available for these switches, but those were either not in stock or much more expensive, so I went with the most basic version. I was worried that they might be too low profile, making it hard to get a grip on the rotating bit, but that hasn’t been an issue. The only potential downside is that they are installed from the front and wired from the back, making them slightly more work to remove/re-install. These are the exact ones I used:
https://vansairforce.net/threads/10k-pot-source.229769/post-1804036
glenadavis
jesse23
howardtlcc
OFF TOPIC:
