Wishing you and yours a happy, safe and RV-filled weekend.
v/r,dr
Rob’s Paint Booth Update
Rob Reece is painting his RV-8 at my home field (52F Aero Valley). He’s teaching himself to paint. He is finishing up the ‘small parts’ now and about to start the ‘big ones’. Popped in to another friend’s hangar recently where the booth lives, to see it in its inflated glory. Said the tent was around 2,500 and you can find them on Amazon. He *thinks* he’ll be about 8 grand in on the total paint job costs, booth included. Texas theme.
Super happy for my friend!
v/r,dr
RV7 To Go
Estevanb
flywithavres
fl-mike
…RE EN2714-013xxxxxx cable
https://vansairforce.net/threads/special-canbus-cable-or-just-m27500-2-conductor.195643/post-1801795
mkraynak
Ideas For Vertex Standard Walkie Talkie Mount/Cradle?
OFF TOPIC:
v/r,dr
v/r,dr
RV7 To Go
Estevanb
Options for alternative panel switches
With a dual 10.3" G3X display, it seems there is precious little room under the displays for switches as the bottom of the panel frame gets in the way. From this standpoint, the Honeywell AM34 switches seem to be the most popular rocker switches and will fit in this space (require 1.14" x 0.75"...
vansairforce.net
flywithavres
Skin layer issue
Hello Brain Trust. I am about to do the permanent joining of the tail cone and fuselage. The completed empennage kit was a purchase from a previous builder. Today’s task was a step by step review of the tail cone assembly instructions in which I discovered a (hopefully) minor error. The F-1079...
vansairforce.net
fl-mike
mkraynak
Troubleshooting Control Stick Trim Wiring
Hello! I just set up and tested the electrical system in my RV-10 - it is controlled through my VP-X Pro. When configuring the trim systems (pitch/roll), I was able to control the servos through my computer/VP-X Configurator, but when I tested the HAT switch on the stick, nothing happened. Any...
vansairforce.net
I’ve been flying my 9A for almost 13 years. I have my backup handheld “mounted” between the seats using Velcro. That has never worked well. I like it there because I have a power socket nearby in the baggage area and like to have it handy just in case. So it’s taken a while but I’m finally sick...
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
