I just replaced all 8 last weekWhy wait. That just delays the results. If you start today, you can get data in one year instead of two.
Tried Airflow Performance nozzles with .024" restrictors. No help. If colder plugs don't help, thinking dirt/disturbed flow in fuel servo????? Any other ideas?So how many hours do you fly in a year? I run IKH27's out past 200 hours. Doesn't seem to be any real wear to the center electrode. The tip of the ground electrode erodes away, mostly just the legs of the "U".
Most likely low nozzle bleed pressure delta; at low flow the fuel exiting the nozzle is poorly atomized. Reducing throttle increases the delta.
I don't fully understand. Altitude is pressure altitude?? Velocity is?
Colder plugs will do nothing to improve or degrade general performance. An exception would be going so cold that there is not enough heat to burn off deposits and cause fouling, which will degrade performance. The goal is to be hot enough to effectively burn off deposits, but not so hot that the plugs erode or cause pre ignition. Beyond that, the heat range make no difference.Tried Airflow Performance nozzles with .024" restrictors. No help. If colder plugs don't help, thinking dirt/disturbed flow in fuel servo????? Any other ideas?
Please don't forget that the Autolite 373 spark plug is NOT a resistor plug. May cause some interference with an electronic ignition. The 386 is a resistor plug.You can also get the autolite 373, which is 3 steps colder than the 386
It should be noted that the L14-u is also not a resistor plug. I experienced no issues when changing and have EI. I do have to wonder if the 386 is also a non resistor plug. All the other autolites in that series are that way and wonder if the specs are wrong. Never measured one. I thought the 14U's may have also been mis reported, but those I measured as no resistance.Please don't forget that the Autolite 373 spark plug is NOT a resistor plug. May cause some interference with an electronic ignition. The 386 is a resistor plug.
L-14U is a hot plug, according to information from the Denso, the manufacturer.Preignition? Will try DENSO L-14U (cooler) plugs, and NGK BR9ES if still cooler needed.
I removed GAMI injectors and tried Airflow Performance injectors with .024" restrictors. No change (except GAMI spread was greater and no longer smooth when LOP). Reinstalled GAMI injectors. Preignition? Will try DENSO L-14U (cooler) plugs, and NGK BR9ES if still cooler needed.
Did not mix AFP and GAMI. GAMI injectors out, AFP injectors and restrictors in.
