Depends on your climate. My needs here in Minnesota are more...robust.I have some help lined up in the cold of February but he wants some heat. What is the safe way to do this?
Ed,I have a diesel/kerosene forced air heater. Fire it up when working in the hangar. Anything above 45 degrees is perfect working weather. 25 degrees not so much….
IMO in an uninsulated hanger it is much easier to dress for the temperature than to try and change the temperature. Warm boots, overalls, hat, and insulated work gloves. Then put an infrared space heater (electric or propane "sunflower") where you put your tools and where you can take a break to warm up.
I've used a couple of different propane models (radiant and forced air) and both had to be turned off after a couple of hours due to overpowering fumes. I'm thinking the ceramic type might be better.I have some help lined up in the cold of February but he wants some heat. What is the safe way to do this?
That's what I did. Much more pleasant to be in the hangar for multiple days in April rather than August. An August condition inspection was brutal. Especially when I would have rather been flying. And November through about February or March here (in the PNW) is a no-go in an unheated (and mostly uninsulated) hangar.The long play is to move the condition inspection to March/April/May or October/November. Those months have plenty of comfortable days where it isn't quite as miserable as doing an inspection in 90 degree heat or 35 degree cold.
Even February should have some decent days if the OP isn't hung up on completing the inspection in a specific 3 (?) day calendar window.
Good advise. I have an insulated hangar with a full sized forced air home furnace and I moved my CI out of the coldest months. We don’t run the heat when not there so concrete floor and tools get cold soaked and just as much an issue of giving you the chills as air temp.The long play is to move the condition inspection to March/April/May or October/November. Those months have plenty of comfortable days where it isn't quite as miserable as doing an inspection in 90 degree heat or 35 degree cold.
How big is the toolbox? I wonder if one of these would help?Good advise. I have an insulated hangar with a full sized forced air home furnace and I moved my CI out of the coldest months. We don’t run the heat when not there so concrete floor and tools get cold soaked and just as much an issue of giving you the chills as air temp.
(Anybody know of a place to buy a heated toolbox?)
Boy is that true. Back when I was using a kerosene bullet heater, the airplane would end up literally dripping water off the wings from condensation, especially over the fuel tanks, as the localized dew point crossed the ambient temp.There are very clean-burning kerosene heaters, but be aware that they put out a lot of water in addition to the heat. I just dress for the cold, with multiple layers from head to toe, and it usually works pretty well. My hangar is as drafty as they get, but it rarely gets below freezing here. The costco outdoor heaters sure look like a good idea for my next winter maintenance session.
Thats a good idea. I use those suits when spraying larger automotive or airplane paint jobs; Learned that a large portion of the dust collected on fresh paint is coming off the operator and not the environment. Man do they make you sweat in the summer. Never connected the dots to think of this for winter use.The guy that did my pre-buy inspection in North Carolina in December wore a tyvek suit. He said it keeps him warm and his clothes clean. I’m going to get one from HF and use it during my condition inspection in February.
I've worn them many times for work, winter and summer. They just block air moving in or out (like wearing a trashbag). Short duration in the winter they might help. But after an hour or so you end up sweating and cold.Thats a good idea. I use those suits when spraying larger automotive or airplane paint jobs; Learned that a large portion of the dust collected on fresh paint is coming off the operator and not the environment. Man do they make you sweat in the summer. Never connected the dots to think of this for winter use.
Back when I had a Warrior and no Reif, I preheated with a ceramic heater and some ducting. Fire inspector threw a fit when he saw it! He likely would have dropped dead if I had been using fuel/open flame.In a leased hangar, I'd be amazed if ignition sources like these would be allowed by the fire marshall or the terms of the lease.
The problem with infra red heaters is they also heat the fuel inside the wings and cause venting of gas fumes. The new hangars being built at Patey Aviation (SPK) were going to supply those in our new hangars until that became known and they switched to forced air natural gas heaters. Those gas heaters require automatic exhaust fans and combustion (make-up) air however, which really jacks the installation cost. Omitting those required items can be hazardous to your health.Before I had forced air systems, I used electric Infra Red heaters suspended from the ceiling over the work area. They only heat you and the objects within their range. They don’t heat the air.
They work but use a lot of electricity.
note the "well ventilated area" requirement in the product descriptionDeWalt 60000 Btu/h 1500 sq ft Forced Air Propane Portable Heater Mfr# F340751 - Ace Hardware
The DXH65FAV forced air propane heater burns at 65,000 BTU/HR and can be adjusted down to 35,000 BTU/HR. Equipped with Quiet Burner Technology this heater operates with 50% less noise than standard units of similar size. Includes a 20 feet hose and regulator and is manufactured with a large...www.acehardware.com
Construction crews use things similar to this up in Montana. Safe, Easy, Relatively Cheap.
I tried that type but found it noisy and needs to be plugged in. Now using theDeWalt 60000 Btu/h 1500 sq ft Forced Air Propane Portable Heater Mfr# F340751 - Ace Hardware
That doesn't make any sense to me. Infra red heaters heat entirely by radiation, so the heat will be absorbed mostly by the skin of the airplane. Any heating of the fuel would only occur by what little conduction could be mustered from the skin after it's heated sufficiently.The problem with infra red heaters is they also heat the fuel inside the wings and cause venting of gas fumes. The new hangars being built at Patey Aviation (SPK) were going to supply those in our new hangars until that became known and they switched to forced air natural gas heaters. Those gas heaters require automatic exhaust fans and combustion (make-up) air however, which really jacks the installation cost. Omitting those required items can be hazardous to your health.
Would never be allowed by most hangar leasing terms nor most fire codes.DeWalt 60000 Btu/h 1500 sq ft Forced Air Propane Portable Heater Mfr# F340751 - Ace Hardware
Money money money or seal up the holes and save a bunch of Money in what ever system you choose.I have some help lined up in the cold of February but he wants some heat. What is the safe way to do this?
from AI:That doesn't make any sense to me. Infra red heaters heat entirely by radiation, so the heat will be absorbed mostly by the skin of the airplane. Any heating of the fuel would only occur by what little conduction could be mustered from the skin after it's heated sufficiently.
I agree....infra red heaters heat the skin of the airplane, little or no effect on fuel contained inside or the air around it. Because it doesn't heat the air, infra red is pretty much only good for people or objects within its radiation field. The source of energy that generates the infra red is another matter and that's the component that a fire marshal is likely going to have an opinion on.from AI:
Infrared heaters directly heat people, aircraft, and floors, not just the air, providing efficient warmth in large, drafty spaces with high ceilings, unlike convection heaters that lose heat upwards; they come in low-intensity (tube) or high-intensity (overhead) types, are energy-efficient, and must be installed according to aviation safety standards like NFPA 409, ensuring heat isn't spilled onto aircraft wings or sensitive areas.
Fire marshals take the infrared venting problem seriously, even if it doesn't make sense to you, and can prohibit it's use in hangars with fueled airplanes.
The forced air gas heater installed in my insulated hangar can raise the hangar temp to 75 degrees with a 1 hour recovery time. Open the big door and let in the freezing air and then close the door and an hour later the hangar will be recovered to 75 degrees.
I would talk to my hangar liability insurance provider before doing anything that involves heat in a hangar. Burning down a row of hangars full of jets could get spendy.
I use the 2 burner Mr. Heater that mounts on top of the 20# portable propane tanks that are available for quick exchange everywhere. Still dress warm naturally, and easy to move the heater to wherever you're working. Just remember it's capable of catastrophic fire if you're working with combustiblesI mostly dress for the weather, but these small propane radiant heaters are pretty effective at taking the edge off when set up behind you a few feet, even with the hangar door open.
This was due to the amazing foresight that the airport board and insurance company had in predicting the extreme A&P shortage - they didn't want him to drop out of the labor market due to smoking-related illness!I'm reminded of an old A&P I once knew that complained that the airport board and insurance would not let him smoke in his hangar.
They had no problem with him firing up a welding torch and repairing an airframe.
What about wearing electrically heated clothing, the heat goes where you go and would use less energy.The fuel is important. Kerosene has sulfur and since all combustion produces water (with sulfur=acid), it will condense on anything cold and corrode. Like tools, etc. I used kerosene heater near some chrome plated wire shelving and it was all eaten off. I have switched to propane only. Moisture is still there but not the sulfuric acid. Low sulfur diesel can yield some aggressive aldehydes and is bad on the lungs, so be sure the combustion is clean. (avoid if possible) Take that from a life long tail pipe sniffer.
Norman I'm going to look into your idea. Never thought of that, thanksWhat about wearing electrically heated clothing, the heat goes where you go and would use less energy.
