Assuming everyone knows what Van's FAB (updraft Filtered AIr Box) is and the "Per Plans" cowl inlet to FAB interface is like. With the Van's set up the connection between cowl inlet and FAB is kind of automatic, a net or lose fit around the bottom with baffle seal, and a separate baffle seal flap on the top. The shape of the induction and airbox is a "D". Note Van recently changed the original design slightly after decades to reduce FAB cracking.
I have a stock cowl I am modifying the cooling air intake and induction inlet. I have a machined round inlets for cooling that matches (smaller of course) the induction machined inlet, Ala: Sam James, LoPresti, inspired by: S.J Miley Et al. "Determination of cooling air mass flow for a horizontally-opposed aircraft engine installation" 1979 Mississippi State University, research.
My question or request for help how to best integrate it this induction (I have the cooling air figured out). The issue is when you put the bottom cowl on how do I attach the flex coupling between the inlet ring and air box. The plan is to do it similar to the air inlet. The challenge is how to attach clamps?
My two ideas to make the connection easily when removing and installing lower cowl are:
NOTE, per "Speed with Economy" placing the induction close to the propeller will increase induction, boosting induction pressure or MAP. I'm a slave to aesthetics, and likely not going to get to the 1" gap needed from the prop blade, but just FYI. (I recall Kent Paser's research showed closer the better, don't recall exact distance but likely in same plane as the cooling air inlets).
- access panel on bottom held on with nut-plates and screws to install clap between flex duct and FAB.
- Induction extended part is removable with semi ridge duct that just slides on with no clamp, a net or loose fit, accept some leakage.
