Balancing the RV-12 prop means running the engine so you will not be in the hangar with access to all your tools. So, after some experience running back and forth to get tools and stuff I needed, wasting a lot of time; I made a list and pack a tool caddy to the run-up area. Your list will vary but here is mine.
This is a complex job, be prepared to spend some time researching, and planning; then doing the work. There is a learning curve; good luck!
Lots of people seem to make this a complex job, but in reality it is dirt simple. You are correcting a slight mass error. If you knew nothing but a clock angle and .ips…as an example
Run 1: .4 IPs @6:00. With nothing else…if you took a 10 gram increment and added it close to 12:00 then re-run
Run 2. .30 IPs @ 5:00. Since 10 grams only moved .1 ips…. Let’s add 15 grams @ 11:00
Run 3 .1 IPs @ 5:40. Let’s reduce the 15 grams@11:00 to 10 grams and add the 5 grams we removed, to1 2:00 for a total of 15@ 12:00
Run4: .075 IPs @ 11:50
Anyway…you should see the point. No charts, no nothing…move mass slightly, establish a move line, using small increments, drive the mass imbalance towards the center.Always remember the mass imbalance …expressed as .ips…is the vibration level off balance from center and clock angle is the direction where the mass is heavy.
I don’t want to say anyone can do it…but my 12 year old helps me on props and helicopter tail rotors and he gets it just fine…
One thing that helps is to draw your own polar chart, .ips and clock angles and just focus on the move line in regard to just the four quadrants of 12:00, 3:00, 6:00 and 9:00
Think only about, above the median line of 3&9. Or below…and left or right on 6 and 12.
Drawing the line depicts moving mass in the correct direction.
8:30 and .35…. Is up and to the right. 1:45 and .22 is down and to the left.
My best advice is if you don’t make it complicated…it’s simple, keep it that way.
