The first step I would suggest is to verify that the pressure reading your fuel pressure sensor is providing is actually an accurate value. Fuel pressure sensors probably have a higher failure rate than fuel pumps.
Chasing after a perceived issue without knowing if it is real, can be a very frustrating process.
By the way, a Lycoming carburetor will perform just fine with fuel pressure as low as .5 psi, but I understand your concern, which is why the first thing I would do is verify that the indication value I am relying on is actually correct.
