markelliott
Member
BCS206 starter will not fit the IO-390 with the avstar fuel servo as the throttle body bolt as indexed hits the back of the starter. Has anyone found a fix for this?
Just to be clear, it isn’t the throttle linkage - it’s the roll pin index to the idle stop. There isn’t enough throw. The throttle can be indexed to this bolt easily by lengthening the rod end bearing.
I’m assuming nobody has successfully installed this starter yet?
Ideas?
Ideas?
