I was planning on putting my AMP100 Hall Effect sensor on the #2 wire from my battery so that I could connect it to my GEA24 to read the net amount of current going out of my battery. I was also hoping it could read negative so I could see the rate at which the battery was charging but I couldn't confirm if that was possible.
Well, I received my AMP100 today and there is no way it will fit around a #2 Tefzel wire. What are other people doing here? Should I be using a different sensor or do I need to move it to a smaller wire?
