Alternator Install
Drippy
OK not thinking things through and being a first time builder I put the prop on to fit the cowling ect and didn't install the alternator belt first.
I just don't see a way around taking the prop off but figured I would ask.
Unfortunately, you'll have to pull the prop. That's one reason why most folks simulate the prop when fitting the cowl.
Now you tell me:-)
I figured - was thinking about doing the light speed ignition system which I believe requires some prop work for a sensor maybe I get do them at the sametime.
