D Drippy Well Known Member Sep 8, 2016 #1 OK not thinking things through and being a first time builder I put the prop on to fit the cowling ect and didn't install the alternator belt first. I just don't see a way around taking the prop off but figured I would ask. Thanks
Auburntsts Well Known Member Sep 8, 2016 #2 Drippy said: OK not thinking things through and being a first time builder I put the prop on to fit the cowling ect and didn't install the alternator belt first. I just don't see a way around taking the prop off but figured I would ask. Thanks Click to expand... Unfortunately, you'll have to pull the prop. That's one reason why most folks simulate the prop when fitting the cowl.
D Drippy Well Known Member Sep 8, 2016 #3 Now you tell me I figured - was thinking about doing the light speed ignition system which I believe requires some prop work for a sensor maybe I get do them at the sametime. Thanks
BillL Well Known Member Friend Sep 8, 2016 #4 yes, take it off. You might need to do it several times
Mike S Senior Curmudgeon Sep 8, 2016 #5 Drippy said: I just don't see a way around taking the prop off but figured I would ask. Click to expand... There is an option, and that is to use a B and C alternator mounted at the vacuum pad. http://www.bandc.aero/lycoming-gear-driven-alternators.aspx But--------I suggest you pull the prop and just use the front alternator. The B and C 8 amp unit is a great backup Last edited: Sep 8, 2016
