I just bought this plane. There is a mechanical constraint that caused a failure of the seal between T-708 (tank access plate) and T-703 (inboard rib). The plans in drawing 16A call for a cork gasket between these two surfaces, but no PN or material specificaiton is called out. I ordered a new T-708, and I'm hoping it includes the gasket. I also ordered MC-236-B2 just in case. Some have suggested using Form-A-Gasket #2.
I drained the tank, so I'm ready to begin the repair process.
I have two questions:
Suggestions I've been offered so far:
- How would you repair the leak?
- How would you resolve the mechanical constraint, so the seal doesn't break again after this repair?
Pics:
- Pull vacuum on the tank fill port and dose a bead of locktite around the perimeter of the access plate to stop the leak. Add elbows to the straight fittings and span a segment of steel braided fuel line between the two fittings.
- Remove, clean, and re-seal the access plate. Add a loop of 3/8 soft aluminum fuel line between the existing fittings.
- Remove the fuselage fitting and replace with grommet. Remove segment of fuel line between fuselage and fuel tank selector. Remove, clean, and re-seal the access plate. Run a new fuel line per the build plans.
View attachment 67346View attachment 67347
You can do it in place. There was a service bulletin years ago where you needed to remove that plate to address the issue and thousands of tanks were repaired in place including removal and replacement of that plate.Do you think the pro-seal can be applied vertically in-place, or do i need to pull the tank and have it so the cover plate opening faces up?
There should be an anti-rotation bracket and lock on the fuel pickup tube inside the cover plate but the rivets that normally attach the bracket are not visible in the photo, so it would be worth checking when the cover is off. The part number for the bracket is T-715.It concerned me as well. I appreciate your feedback, and my gut tells me I need to not cut corners here and just modify it, so it's compliant with the plans.
Tom made my flexible lines, and they work magnificently. I would never have anyone else make lines for me.You probably already know that the fuel line (as it is) is not only not per plans, it looks outright dangerous to me. You can either return it to “per plans” with the grommet and new fuel line on the fuselage side, or you might be able to get Tom at TS FLightlines to make a flexible hose with right-angle fittings on each end that could fit in there.
You are so blessed not to be halfway around the worldTom made my flexible lines, and they work magnificently. I would never have anyone else make lines for me.
Get a flexible hose with 90-fittings on each end, that will fit. It will also raise the pressure drop between the tank and the pump, which normally a thing to avoid.The third suggestion is the way to go and make it like the plans. I don't think there is enough space between the fittings in the wing root to make a looped line.
Van's current recommendation is to seal the cover plate on with tank sealant and no gasket at all.
While this is true, but more bends in the fuel lines can introduce more problems. If the airplane performs fines today with the correct fuel flow and fuel pressure, then fix the leak instead of opening up a new problem.Regarding your second question; It's standard industry practice as well as a good design principle to never run a hard line like this without at least one bend
Except that the leak is almost certainly a direct response to the installation.While this is true, but more bends in the fuel lines can introduce more problems. If the airplane performs fines today with the correct fuel flow and fuel pressure, then fix the leak instead of opening up a new problem.
