Well, I've started building an RV-7A
I'm the third owner of this Kit and if you haven't read Vans warnings about buying older kits, particulary the bit about unboxed, original packaging you should.
When I unboxed the kit for the first time in its 14 year life, this is the result of storing aluminum in carboard for 14 years
Both HS-609PP pieces have corrosion like this
So, 2 new HS-609PP's are on order, and I moved on to the Vertical Stabiliser
