Yup - I think the behavior fits your quote much better; 3 failures and changing nothing and understanding nothing between each -- yeah, that's insane.I have seen posters here that are on their third PP alternator. Does that not also fit your qoute? What about “… repeating the same behavior looking for a different result.” I am not saying they are universal junk. But i see a fair number of folks coming here reporting problems with their pp alternators; many failing after 100-200 hours. I just never hear that about others. Certainly anecdotal data, but just don’t see how you can ignore the significant number of posts with pp problems and the lack of same with others.
I hear/see about the same number as you do, and every one of them is user/builder/installer error, and it's not just Plane Power. I just went through this with an -8A with IO-360-A1A with an Autozone 14684R installed; no heat shields, broken mount, and loaded with oil because of a blown nose seal -- yeah, the SRE bearing was shot (shrug).
Are the PP units more sensitive to builder F-ups? Possibly, probably, maybe. From an engineering perspective tho, it's impossible to say because the data is obscured by primary failures.
