~$2600 for one PMag? I've got an old one and like it, but maybe it's time to discuss an open source DIY ignition project - Dan, Larry and others have provided all the info in the MegaJolt thread previously. We could have a very simple, variable timing(2 setting), user maintainable Electronic ignition for less than an AMU. This is not original thinking by me.
The only really hard part (IMO)is the trigger - and I'm betting that we could crowd source a good design for that with all the smarts we have here on VAF - for either a mag hole or crankshaft trigger. We need a solution for those that don't have access to a lathe and machine tools, or a vendor to make those parts. Services like Send Cut Send allow you to order parts to assemble - we just need a design. Maybe something could be done with an old magneto - it has a housing and a shaft. Would just need to mount a trigger wheel and the VR sensors inside the mag case (it would be tight)
As for functionality, you have 2 switches - one for power and one to switch the VR sensor(effectively switching timing) ROP takeoff timing at ~22deg btdc and LOP cruise timing at ~32deg btdc) - could change the values via a bit of clocking of the trigger at install. . That may be plenty for many people. The only electronic component is the EDIS module - it can, and should, be mounted on the cold side of the firewall. They seem pretty robust. The wiring is dead simple. Want to keep the spark if the alternator dies? - pair it with a Trad Mag or install a backup battery.
Costs:
Let me know what I am missing here - probably a lot. Once again - this has all been covered before, but as costs get crazy, it makes more and more sense. If you need a 10x10 timing table, add $300- 400 for a MegaJolt or MegaSquirt. For $ 15 more, get a cockpit display you can build yourself - I know a guy.........
I'll toss out a quick and dirty block diagram. Discuss amongst yourselves - tell me how wrong I am. Fire suit on - I am ready for the abuse. Don't let the PE Bros win!
Costs:
