I don't have any inside information, and all my opinions are my own, but I can tell you, having worked for an OEM for most of my adult life, my observation is that once something is certified, unless there's a compelling reason to change, it tends to stay that way unless there's block point change that overhauls the entire thing. Plus, gascolators on piston airplanes are required in certain countries whether the plane is fuel injection or not and it's easier to have a one size fits all approach.I tend to think you may be correct…not sure why they installed them on my 185’s, or Aerostars, or R-44 or any others…you’d think if it was worthless…the big dawgs would have deleted them long ago…but who knows.
A parallel example of this is that rotating beacons aren't specifically required in the U.S. for new pt.23 airplanes, but you'll not see a new 172 rolling out of Kansas without one. It's always been that way, rotating beacons are cheaper than the cost of making the change and it's would be more hassle to add one on a plane that sells into South Africa (for example) at the last minute than just shotgun one onto every airplane coming down the line.
