Did an oil change on my F1 Rocket this week, and found some metal bits in the oil sump screen.
After some consulting, we concluded that they were parts of the bearing cages from the magneto drive bearing in the accessory case.
Pulled the left mag (the right mag is a Lightspeed, and there’s no drive gear on that side), and can see the bearing in the accessory case - all 8 balls are still in the ring, but they’re bunched together in the bottom 60% of the circle, instead of looking like an intact bearing like the picture with the red circle.
So it appears that the bearing cages have failed and fallen out of the ring. And at least two small bits made their way to the sump screen.
Unfortunately, I’ve had this airplane for 6 months, and there’s no record of the sump screen being cleaned in the last 15 years / 340 tach hours.
The original owner/builder (not the one I bought it from) cleaned the screen twice in the first 260 hours, and never found anything. All that to say, I don’t know how long ago the bearing cages failed, or how long those bits have been in the sump screen.
My instinct is to find as many of the broken bits as possible. The plan is to use a borscope and magnet through the oil drain ports and the sump screen ports to look in the oil pan. Then look down from the open holes where the mags go to try to find some more bits.
Thoughts from the group? What should I be concerned about, and how can I mitigate the risk of one of those missing pieces damaging something?
Thanks!
Thanks!
