Yeah, it becomes a time thing; I would rather be working on my build than trying to figure out how to do a website...
That is the one nice thing about kit log pro...enter you work and photos and you are done. Unfortunately, KLP seems to have been abandoned...
Hosting your work logs on a product's servers comes with two real risks:
the service can disappear, and doing it properly adds ongoing monthly cost. With KitFlight, you own your logs and can publish them online for free using GitHub Pages. Zero dependency on a third party that may not be around in a few years. It takes less than hour to set up once, and after that you're just adding new entries as you go.
That said, KitFlight's focus is on being the best mobile-friendly, offline-first work log for builders, without too many "nice to have"s. Photos, annotations, compliance tracking, parts inventory, cross-referencing are all in the focus. Everything is stored on your own devices. No subscription, no lock-in. You can import, export, and print your logs, publish them as a static site, or analyze them in whatever tools you prefer. If you want something more custom, you can even vibe-code your own site on top of the export.
One feature worth highlighting: photo annotations. Instead of writing paragraphs trying to describe what you did, you can mark up photos directly. Label parts, point to specific areas, add notes right on the image. It makes logs far easier to read and is a much better way to pass on knowledge, especially during inspection or when helping another builder with the same kit. If you're not already using it, I'd encourage you to give it a try, it sounds like exactly what you're looking for. All exportable and printable (added a simple PDF export example, also you may check the web export
https://log.traumvomfliegen.de/work log/linkes-hhenruder-skelett-weiter/).
