In my limited experience, a close tolerance bolt may help, but holes with excess wear rarely wear round. Hence, it won’t keep the joint from continuing to wear. You never know though, it’s a cheap fix if it works.Just an FYI -- the corresponding close-tolerance bolt designation for an AN3-14A is AN173-14A, assuming the RV-7A uses the AN3-14A. Cost is $0.86 per bolt at Aircraft Spruce and Specially. If it were me and my airplane, I would fix this before flying again -- from one engineer to another.
A known repair is welding up the holes and drilling again per the build manual. This has been done many times to fix poorly aligned horns.
Not saying other suggestions won’t work, or be even better, but welding the horns and putting this back to plans we know works.
