Back when DanH did the oil filter testing, and at about the same time, the cost of Champion and Tempest filters went through the roof, I went looking for what I thought would be the closest equivalent WIX filter, and I found the 51624 filter, which is actually intended as a hydraulic transmission filter, but has very similar specs to the aircraft filters.
So I removed my Tempest 48108 filter and replaced it with a WIX 51624.
That was 30 flight hrs ago.
Today I changed my oil, and cut open the filter. I should have taken a picture. The WIX filter collapsed. The collapse bent and twisted the metal end plates on the filter element, so I imagine it has been just bypassing oil all this time. (glad it was only 30 hrs).
Oh, by the way in case someone asks, the oil is Phillips Victory 20-50.
So...I put a Tempest 48108 filter back on. The price of that particular WIX filter has increased to match the price of the Tempest filter anyway.
Here is the spec sheet on the WIX 51624 filter:
So it looks like the burst pressure and the bypass valve pressure setting are very similar to the Tempest 48108. I'm wondering if it was defective and the bypass valve didn't function correctly?
I suppose it could be some other failure, such as the Vernatherm stuck closed. But it's too coincidental that it happened to the WIX filter. So I'm not going to look any further unless the next filter fails too.
