Hey Dan and Carl,
Data is a good thing!
Until recently, James aircraft was still advertising the MkIV Air filter assembly for IO-540's up to 300HP. I unfortunately purchased 2 of these units.
Talking at length with Rob Heap (Ex-Engineer at Van's Aircraft ) who solved the RV-14 EXP intake solution, he recommended getting it tested by Don at Air Flow Performance.
So I boxed up and sent from Australia 2 x assembled MkIV Air filter assemblies and a FM-300R FCU and a SDS 90mm Throttle Body for testing.
The results where abysmal !
The Mk-IV Air Filter Assembly is exactly 50 % too small for the IO-540!
The Alternate Air Design of the MK-IV will not run an IO-540 with out extreme surging and richness on the FM300R, it may run on the SDS EMF-6EFII as it has the ability to adjust rapidly but is massively undersized for the IO-540.
The Conical Filter is massively undersized to run the IO-540
Extracts from Don's Testing are as follows,
These were both modified MkIV's with 4" intakes.
Don tested both air filter assemblies with and with and without air-filters and also tested the comparison between the SDS 90mm and the FM300B.
What was interesting was the clever design of the FM300R FCU out-performed the SDS 90mm Throttle body.
Air Flow Performance for the win!
I was a very expensive journey with my out-of pocket costs exceeding $6000 AUD.
To the credit of Jimmy at James Aircraft, he was copied all results and has since removed the MKIV from his website.
I have since gone on and designed a completely new lower cowl and air filter assembly that satisfies all of my design goals,
-Fully Filtered Air with no restrictions
-Oversized Filter Assy rated at 140% of IO-540 requirements
-Accomodate's an A/C equiped IO-540
It was loosely based on the Panthera but CFD testing has improved on this design.
I have Version 1 and 2 flying on 2 x RV-10's and flight testing has been very successful. My talented Team hope to have the final version finished and ready for market release some time before Osh 26.
Standby.....
