Regarding mice, I had a live and let live philosophy that worked for quite a few years ... until they got to some aluminum parts, wiring, chewing spare upholstery etc as well as leaving excrement in my cabinets and drawers. Now this means WAR.
I tried the traditional mouse traps, and they did not work for me.
My nephews (farmers) told me that they use the bucket and beer can method with great success. Basically you get yourself a 5 gallon bucket, an empty beer can (if it is full, you know what to do), a metal coat hangar, and 1 gallon of automotive antifreeze (not the RV plumbing ecological stuff).
Here is what I did:
- Drill axial holes in the (empty, of course) beer can
- Drill two holes 180 degrees apart, near the top of the bucket
- Straighten the coat hangar and cut yourself a straight piece of wire that is a couple of inches longer than the diameter of the bucket diameter.
- run the coat hangar wire through the bucket and beer can.
- Using some pliers, make a small bend at each end of the can to keep the can in your preferred position. I placed the can an inch or two away from the edge of the bucket.
- Bend the wire portions that are outside the bucket to prevent the wire from drifting out of these holes.
- Place some peanut butter on the can. Don't need much, just spread it near the center of the can along its circumference.
- For this step you can use water if you are in warm climates, but up here it gets really cold. In my case I used automotive antifreeze mixed 1:1 with water giving 2 gallons and poured it into the bucket.
- Make a small ramp of wood to the lip of the bucket. Any piece of wood will do. You can attach it, but I have just leaned it to the bucket and it has worked for me for almost a decade without falling.
Do not use RV plumbing antifreeze. I tried that the first year, trying to be ecological and all, and caught no mice. Why? Well, that type of antifreeze turns into a slush when cold and allows the mice to hop out of the bucket. After the first month, I replaced it with automotive antifreeze and I eliminated 13 mice that winter.
Some salient points about this system:
- No bait reloading required for the season. Just empty the floating contents whenever you get to the hangar next.
- Auto resetting. Even when seeing their brethren at the bottom, the mice have this bravado that they can do much better than the previous guys... almost like when pilots armchair read accident reports and feel that they would have fared so much better if they were placed in that same situation
- I have found up to half dozen mice (well preserved) at one time in the antifreeze. Just do not allow wildlife to feed on the corpses (unless you use only water).
- Low cost, quick to build, very effective.
- When off season (spring, summer, early fall), I filter and store the antifreeze, clean the can and store everything for the next winter.
Now after a few years, my catch is one or two mice every winter season. Works great for me. Many thanks to my nephews for the suggestion.
Here is one site with some instructions/images to give you a better idea:
https://www.trap-anything.com/homemade-mouse-trap.html
Check with Mr. Google or YouTube for more information.
