What parameter/indication are you using to determine alternator condition?My 200 hour Denso alternator drops offline line when I am at full RPM. It seems to work fine when I pull the prop below 2500. Ideas?
200 hours implies you haven't checked or reset belt tension since installation. Could be too loose, and if it's been slipping, the belt could be glazed by now too.My 200 hour Denso alternator drops offline line when I am at full RPM. It seems to work fine when I pull the prop below 2500. Ideas?
That was my first move, the belt needed some tension but that didn’t fix it. It seems to cycle on and off until the rpm is reduced.200 hours implies you haven't checked or reset belt tension since installation. Could be too loose, and if it's been slipping, the belt could be glazed by now too.
New V-belts almost always require re-tensioning after a few hours of use. Once you do that, the tension will remain constant.
As to why only over 2500 rpm; the faster it rotates, the more centrifugal force on the belt (pulls away from the pulley, reducing tension a bit). Plus, due to bearing friction, rotor windage and fan drag, it probably takes more power to spin faster.
When the belt was off, did you examine the feel of the pulley? Loose bearings could potentially cause something like this.That was my first move, the belt needed some tension but that didn’t fix it. It seems to cycle on and off until the rpm is reduced.
Gerhardt beat me to it. First suspect a slipping belt. A glazed belt needs to be replaced. Tightening a glazed belt is like peeing into the wind. Second would be a poor electrical connection exterior to the alternator. Extra vibration at full power might cause to much vibration on a less than proper wire connection.200 hours implies you haven't checked or reset belt tension since installation. Could be too loose, and if it's been slipping, the belt could be glazed by now too.
The belt seems fine, I replaced it at overhaul, 130 hours ago. It was just a little less than optimum tension but that didn’t change anything. A friend suggested the internal regulator in the alternator may be failing and sensing over voltage.When the belt was off, did you examine the feel of the pulley? Loose bearings could potentially cause something like this.
+1Since the OP didn't indicate what "offline" meant, we're left to guess :/
My guess, after dissecting a few of these things, is a broken field and/or sense wire. (Or fretted/fractured connection thereto).
I wasn’t referring to the belt. I meant yank the pulley around to determine the condition of the bearings supporting the main shaft. You can tell pretty easily if there is a problem.The belt seems fine, I replaced it at overhaul, 130 hours ago. It was just a little less than optimum tension but that didn’t change anything. A friend suggested the internal regulator in the alternator may be failing and sensing over voltage.
I am here, you can speak to the OP directly. Offline meaning it is charging fine until I apply takeoff power. It then stops charging and the bus voltage drops to loaded battery volts. Staying at full rpm, it will cycle online (charging) for a couple seconds, then offline again. I have seen this happen on several consecutive flights. It has never stopped charging with the rpm below 2500.Since the OP didn't indicate what "offline" meant, we're left to guess :/
How do you know it's "charging" - what gauge are you looking at?I am here, you can speak to the OP directly. Offline meaning it is charging fine until I apply takeoff power. It then stops charging and the bus voltage drops to loaded battery volts. Staying at full rpm, it will cycle online (charging) for a couple seconds, then offline again. I have seen this happen on several consecutive flights. It has never stopped charging with the rpm below 2500.
I will get the data plate when I pull the cowling in the next few days and report back.How do you know it's "charging" - what gauge are you looking at?
Similarly for bus and "loaded battery" voltage - what're the actual numbers you're observing?
While we're at it, what is the alternator in question? You indicate "Denso", but which model specifically?
Bus voltage as read by the G3 is normally 13.8-14.2. When there is no output from the alternator, it quickly drops to the lo 12’s…..
This is the unit I purchased at O’Reilly AP a few years ago. I also added a Monkworkz BU generator.Update,
I pulled the alternator today and it is a NAPA brand not Denso. They would warranty it but it’s not in stock and may not be for many months.
We tried to spin it up at Oreilly but the machine refused to spin it as it said it has an internal failure.
I found what may work for $100 at Oreilly, it comes up as a Nissan Altima alternator.
What automotive alternators are others using?
Did you have to pull the pulley and replace it with a V? How much trouble was that?This is the unit I purchased at O’Reilly AP a few years ago. I also added a Monkworkz BU generator.
Don’t go by the picture, the alternator comes with a V-belt pulley, use the part number.Did you have to pull the pulley and replace it with a V? How much trouble was that?
I looked it up on Oreilley’s website, I think that’s the unit I have comin in this afternoon.Don’t go by the picture, the alternator comes with a V-belt pulley, use the part number.
The three pin plug is one horizontal above two vertical spades and only one wire is used. My plane has never had an external regulator, what is the caution you mentioned?...and the mystery deepens...
This unit "could be" self exciting, using the ND 126000-0550, -0900 regulator (or one of its clones -- i.e. WAI IR250SE), so apply some caution here.
By any chance can you share a picture of the 3 pin plug that goes into the unit? That will help triangulate what kind of replacement regulator to buy.
Some of these are "self exciting" and the plug does nothing.The three pin plug is one horizontal above two vertical spades and only one wire is used. My plane has never had an external regulator, what is the caution you mentioned?
Bearings seemed fine but O’Reilly tried to spin it up and the computer said internal malfunction and wouldn’t spin it.I wasn’t referring to the belt. I meant yank the pulley around to determine the condition of the bearings supporting the main shaft. You can tell pretty easily if there is a problem.
I bought this exact alternator and it seems to be fine now. I had to add a sense wire as the previous one only needed the field current and sensed internally.This is the unit I purchased at O’Reilly AP a few years ago. I also added a Monkworkz BU generator.
This is the replacement alternator. I had to add a sense wire for the internal regulator to work.Some of these are "self exciting" and the plug does nothing.
Out of curiosity, do you have a picture of the harness/plug available?
Mconner7,My 200 hour Denso alternator drops offline line when I am at full RPM. It seems to work fine when I pull the prop below 2500. Ideas?
What did you do with the original unit? Core exchange?This is the replacement alternator. I had to add a sense wire for the internal regulator to work.
Yes the old alternator cost me $70 almost three years ago and was worth $40 as a core.What did you do with the original unit? Core exchange?
That was my first thought. I tightened the belt with experienced mechanics looking on to no avail. I think the Mexican reduilds are of marginal quality.Mconner7,
Belt tension?
It loosens up after use like a guitar string going out of tune.
Daddyman58
Mconner7,
Belt tension?
Daddyman58
Mconner7,That was my first thought. I tightened the belt with experienced mechanics looking on to no avail. I think the Mexican reduilds are of marginal quality.
Buy a new regulator -- $30 or so from Zorkos.com (https://www.shopzorkos.com/XrefCategory/VR-1265S/IN250)Update, flew today and the first 10 minutes went fine. The. The voltage rapidly rose to 16 when I shut down the field switch. I tried multiple times and the regulator always went into over volts after a few minutes. I am pretty sure this is an internal regulator failure.
I suspect the Japanese alternators that are rebuilt in Mexico are of poor quality. My next step will be to try and find a new (not rebuilt) alternator. Any one have a good source?
Two questions..do the regulators offer over voltage protection and how/where do they mount?Buy a new regulator -- $30 or so from Zorkos.com (https://www.shopzorkos.com/XrefCategory/VR-1265S/IN250)
As I advised earlier, make sure it's the correct one for this application (Not Self-exciting, Not Single-wire, Not 18.9V, etc.)
The IN250 has a 14.5V set point which may seem a little "hot". If you want a little lower bus voltage, you can try the IN256; it has a 14.0V set point.
On overvoltage - some do, some don't.Two questions..do the regulators offer over voltage protection and how/where do they mount?
My gut feeling is that the Mexican rebuilds are of poor quality. While the one I have is warrantied, is adding a new VR to a poor quality alternator worth the effort or do I chalk it up to bad luck and swap the unit…..On overvoltage - some do, some don't.
I've found that the overvoltage feature is just an indication and not protection (lamp active vs field disablement or crowbar). The only one that I'm aware of that has OV Protection is the PlanePower/Unipoint YR-6621 variant which is available from A/C Spruce (https://www.aircraftspruce.com/catalog/pnpages/07-17968.php) -- however, this unit uses a different 3-pin plug than what you have.
There are two typical sizes of the ND style internal regulator - 57.5mm and 63.5mm - and they mount on the rear of the alternator with 3 short and 2 longer screws. Three short screws connect the Brush Hi & Lo, B+ output, Field Input, Stator Output and the two longer screws anchor the heatsink corners on regulator to the SRE bracket.
(YR-6621 image attached -- note difference in 3 pin plug shape)
Sorry, can't help you with feelings -- only objective data. What data do you have that suggests "poor quality?"My gut feeling is that the Mexican rebuilds are of poor quality. While the one I have is warrantied, is adding a new VR to a poor quality alternator worth the effort or do I chalk it up to bad luck and swap the unit…..
One additional question, I have a three pin plug, one is power in, one is sense for the VR, and the one I didn’t wire is the lamp pin as I assumed that’s just for an idiot light in automotive applications. Is it OK not to put a resistor/lamp on the light pin?
Failure of this newly overhauled unit….Thanks for all your input.Sorry, can't help you with feelings -- only objective data. What data do you have that suggests "poor quality?"
The LAMP wire doesn't need to be connected to anything.
Hard to tell from your posts -- what was the "failure" exactly -- Exceedance of 14.4V? Maybe the unit is actually a 14.9V or 15.4 or 18.9V... Or, perhaps the sense wire is connected to some place it shouldn't be, or has excessive resistance? For that matter, perhaps the alternator doesn't have a solid connection to ground (battery [-])Failure of this newly overhauled unit….Thanks for all your input.
Most alternators do not fail from the core hardware on ND's. It is usually something in the VR module that brian showed or the diode pack. PP is an exception, as they mess with the core hardware. So the core Alt is NOT junk and probably in good shape. The cheap rebuilders will put in the absolute cheapest off shore parts (VR module and diode pack) they can find and therefore fail MUCH sooner than good ones. This is why I try to buy remans direct from ND or at least find a reputable brand, which is difficult in todays world.My gut feeling is that the Mexican rebuilds are of poor quality. While the one I have is warrantied, is adding a new VR to a poor quality alternator worth the effort or do I chalk it up to bad luck and swap the unit…..
What "core hardware" do they mess with?Most alternators do not fail from the core hardware on ND's. It is usually something in the VR module that brian showed or the diode pack. PP is an exception, as they mess with the core hardware. So the core Alt is NOT junk and probably in good shape. The cheap rebuilders will put in the absolute cheapest off shore parts (VR module and diode pack) they can find and therefore fail quickly. This is why I try to but remans direct from ND or at least find a reputable brand, which is difficult in todays world.
Therefore, there is a good chance that replacing the module will address your issue. Or you can scrap it and start fresh with a better quality reman.
The bearing retainer.What "core hardware" do they mess with?
The bearing retainer isn't a part of the design of any of <= ~106MM SRE ND & clones; Plane power doesn't deviate from this. (AL12-EI60, ALT5020)The bearing retainer.
...that's how I roll@bjdecker
What are your feelings on converting non-aviation alts for use with external VR/OV protection? I saved an article from here showing how to do such. Would seem to be a worthy endeavor for those wanting to go that route. Strongly considered it myself.
Background. I have had an undetected OV condition; Toyota not aircraft with expensive avionics. Killed my POS radio and blew the caps off of the battery and ruined paint on the hood. This is the foundation for my non-acceptance of any aircraft application of any alt without OV protection.
I thought i read one of your posts where you took apart a pp and the bore in the case end holding the bearing was so worn that the armature moved out so much that it was wearing away the case. Was that not a pp alternator? I thought that i had read many other posters having similar issues. I defer to your expertise here, as i only know what i read here. Have never owned a pp and likely never will.The bearing retainer isn't a part of the design of any of <= ~106MM SRE ND & clones; Plane power doesn't deviate from this. (AL12-EI60, ALT5020)
FWIW - The bearing retainer doesn't come into play until the ~118MM SRE's, which Plane Power markets as the AL12-EI70 (70A)...
So, net-net, the belief that Plane Power somehow alters or deviates core hardware isn't based in fact.
What they do modify (or deviate from "standard") is the Pulley (2.75", 11MM, V-groove) and the regulator - it's a Unipoint/Victory YR-6621, which is a discrete component implementation of the Denso 126000-2400 (Transpo IN240) with an SCR and Field Supply/Brush modification to support Overvoltage Crowbar.
