For those that are thinking about doing their own paint work, I'd suggest hitting the local auto salvage and buying the cheapest metal fender and hood or trunk lid you can get and use it for practice. Do the prep work and paint it white and experiment. Then sand it all down or strip it and then repeat with high gloss black. Between both colors, it's a good way to learn and figure out the skill set needed to do at least a reasonable job of it. It will also give you a chance to learn about mixing, thinning and using additives to adjust the curing and time to see if you really want to do it yourself. Better to learn on the 100$ junkyard parts than mess something up on your fresh built airplane.
