Can you share who painted it?
I had everything painted before final assembly with the tail and wings done first. However, the paint shop had to match the fuselage hue to the same hue as the tail and wings since they were done at very different times. They did this by mixing small batches of Imron and spraying small strips onto a wing inspection plate until they matched the wings. Otherwise, I highly recommend doing that! Here's what my RV-9A project looked like in early summer of 2004, just before final assembly. Just need to be a bit more careful while handling the parts, but the painter also placed special stick-on protective material onto where the parts contact the jigs (mainly the wings and horizontal tail).My 172 a few years ago was 20k ball park to start, 2yr waitlist.
Can an RV be painted white in smaller sections before final assembly?
I have a lot of time with Imron. Both old and new.One must remember that Imron was originally created for the heavy-duty truck industry and has been used on airplanes for years! I've had Imron on two of my own airplanes, and it's extremely durable if done right. However, mixing the hardener to paint ratio is absolutely critical, and it's not the same ratio as PPG. Paint shops have been known to get the paint to hardener radio wrong on Imron jobs now that PPG is popular. My painter mentioned this to me when I asked for Imron instead of PPG. He gladly shot Imron over a "shiny green" zinc chromate epoxy primer that he first applied (preferred primer for both Imron or PPG). In addition, the bare aluminum surface needs to be properly Alodined, rinsed thoroughly and dried before any primer is applied -- VERY important prep steps. If these steps are followed, then Imron paint is "tuff as nails" and will last for years looking nearly new! My 20-year old RV-9A paint job is a good example, and no paint chips! But, I also hanger the airplane because we are based out of Paine Field WA. While building the airplane, I also applied epoxy primer on all internal structures -- well wroth the extra time and effort!
I wrote an article for Kitplanes. Vinyl 101. They haven't published, but I can send the draft if you want. Black is Kirker Ultra Glo Single Stage Urethane. Yellow is 3M 2080. Eagle is just a vinyl graphic. Probably $2000 including paint, tools and the eagle. Learning curve isn't anywhere near learning how to spray paint!Is that doing it yourself or someone doing it for you? Would it be pretty simple for someone with no mechanical aptitude?
I think in all of these paint threads the painting and bodywork are conflated together. I'd estimate the final prep and paint (the half talent/ half practice skill) is less than 100hrs of that 1000. The rest is all bodywork, filling, sanding, fitting, trimming, etc.From my neighbor -
Exactly. Some people have the skills to do it right, most of us do not. Evoke put over 1000 person-hours of labor in my RV-10 paint and around $10K in materials. Was it worth $40k? To me, yes. There is a reason they have a multi-year waiting list and the majority of the award winning planes at SNF and OSH are painted (or the scheme is designed) by them. We spend $60k or more on a pre-wired panel, $100K on an engine. $40k on a show quality paint job that will last for many years is a bargain.
Beautiful aircraft!! Just curious how vinyl would do on an RV-12 with pull rivets?You could give vinyl a try, 8 years on my hangared -7.
About $ 1500 in materials.View attachment 86162
Some say it can be done… I wouldn’t have the patience to deal with all those rivets though. My 6 with flush rivets was no problem at all.Beautiful aircraft!! Just curious how vinyl would do on an RV-12 with pull rivets?
My hangar neighbors vinyl his RV12 and another vinyl his Zenith. Both look great. Unless you are standing next to the airplane you don't know they have vinyl. The RV12 builder said the toughest was to blend the vinyl at the end of the trailing edges and the small compound curves of the appendages. The Zenith has last over 6 years and counting. The RV12 has been on for over a year.Beautiful aircraft!! Just curious how vinyl would do on an RV-12 with pull rivets?
Just got the airplane back from paint.I can recommend JetCrafters at Safford, AZ (KSAD). That's where my 8A is right now. http://jetcrafters.com
Love that scheme!!
Prestige Aircraft Painting in Swanton, VermontCan you share who painted it
When did you have this painted. Looks great.Have thus far been delighted with my RV-14A's $8500, 2wk TAT, SW Acry-Glo paint job from these folks
View attachment 88570View attachment 88571
The going rate for a bare RV never painted before $20k to $25k usd. Stripping paint will add. Recommend you pay extra and got one that is painted and looks nice already.If I buy a used RV (6-9 model), how much should I plan on spending to have a professional paint the aircraft (I would not be doing it myself)? I think it’s safe to assume it’ll be at least $20k. Another question I have is does it add to the cost to have it painted more than one color versus the entire airframe being just one color? And is the old paint stripped off, or is it simply painted over? Would this add any noticeable weight (the only dumb question is the one you don’t ask)?
I wrote an article for Kitplanes. Vinyl 101. They haven't published, but I can send the draft if you want. Black is Kirker Ultra Glo Single Stage Urethane. Yellow is 3M 2080. Eagle is just a vinyl graphic. Probably $2000 including paint, tools and the eagle. Learning curve isn't anywhere near learning how to spray paint!View attachment 86460
I am building a RV-12is and would love to learn how to do a vinyl covering. I would also like to read the article you wroteI wrote an article for Kitplanes. Vinyl 101. They haven't published, but I can send the draft if you want. Black is Kirker Ultra Glo Single Stage Urethane. Yellow is 3M 2080. Eagle is just a vinyl graphic. Probably $2000 including paint, tools and the eagle. Learning curve isn't anywhere near learning how to spray paint!View attachment 86460
Shoot me an e-mail to a private message. I'll send the draft.I am building a RV-12is and would love to learn how to do a vinyl covering. I would also like to read the article you wrote
The FAA has prohibited wraps on certified aircraft without certification see the FAA Small Airplane Issues List, item A-0101.May not be an issue with metal airplanes, but Cirrus has a SB out about wraps and p-static issues. YMMV
Ps. I do like the options with wraps however!
Plus $8500 labor.[email protected]Shoot me an e-mail to a private message. I'll send the draft.
The learning curve is no where near as steep as paint. Tools and materials are cheaper too.
Hmm that's going to be one heavy paint job based on the quantity of paint, weight doesn't matter so much for a Corvette but an experienced aircraft painter should apply no more than is necessary!View attachment 88808 Plus $8500 labor.
Atlanta GA area. I’m doing the full paint strip myself. https://webbertekllc.com/sunset-strip
They have their own everything including an inflatable paint booth.
My aircraft will be their first. They have automotive experience doing stuff like Corvettes. They want to use my aircraft as their calling card for future customers. If they do a great job. I’m sure their dance card will fill up quickly.
Thanks for posting that, Dan. I did not know the FAA Small Airplane Issues List existed. A quick search brought it up and I scanned through part of it. Pretty eye opening for me. Especially the item mentioning the intended use of AI in aircraft software... yikes! This list should have it's own VAF thread.The FAA has prohibited wraps on certified aircraft without certification see the FAA Small Airplane Issues List, item A-0101.
EASA has similar requirements. While we are not certified, the concerns that are documented could be problematic regardless of the type of airworthiness certificate.
Information is expensive. This person has never painted an aircraft before and the quantity of paint purchased is based on coverage calculations.Hmm that's going to be one heavy paint job based on the quantity of paint, weight doesn't matter so much for a Corvette but an experienced aircraft painter should apply no more than is necessary!![]()
What he^ said.Hmm that's going to be one heavy paint job based on the quantity of paint, weight doesn't matter so much for a Corvette but an experienced aircraft painter should apply no more than is necessary!![]()
I'm interested to hear how this turns out. I don't have a lot of budget for paint and at this point I would be fine with just a single color (white or dark blue) all over. Assuming I don't just go buy some PSX-700 and do a roll-and-tip...View attachment 88808 Plus $8500 labor.
You know how to paint. If the white is holding up, sand the accents off and spray those areas white. Then add the vinyl accents.Interesting thread, I'm buying an aircraft that is mostly white (single stage painted about 10 years ago) with some tiny blue accents. I'm thinking I would love to dress it up a little and make it mine. Checkerboard tail of course.
I know how to paint, not something I love to do as it was usually done on crashed up motorcycle bodywork (Fiberglass) but this would add some weight, and I seem to remember something about painting control surfaces being critical?
A vinyl wrap over the cowl, tail, and wingtips would be just as nice. Are there people selling pre-cut pieces or do you buy sheets of the stuff and cut to fit?
10 years ago the price for a basic 3 color paint job cost about $12k. Just the cost of materials has gone up a bunch since then. Especially after Covid. When you add in the costs of everything else associated with a paint job, $20-$25k doesn’t seem bad.I am encouraged by the sub $20,000-$25,000 quotes.... $8,500 to $15,000k seems reasonable.
I am going no paint and all fiberglass primed. I did this with my first RV. I might try vinyl for fun and protection on the belly. Want to keep oil off the belly...
Would love to get some checkers from youYou could give vinyl a try, 8 years on my hangared -7.
The perfect paint scheme... Clean, short and fast. Just sitting there!I prepped my plane an I did the cut/buff after paint. A friend did the spraying. The prep was a LOT of work! Total cost was $5500. Next time I’ll just go to work and pay someone.
Very nice!! How long was the waiting list to get in and how long was it in the paint shop for?16.5K from Corona Air Paint. They gave me some prior examples of their work and what they charged ($14k to $18k) and they came in bang on target. Very happy with what they delivered. Came out of the paint shop two weeks ago.View attachment 86588
Spray Cans
That's all I'm interested in. I didn't build a showplane...Some of us just want basic paint durability and protection for the metal
