Ted Christopher
The RV9A I bought a few weeks ago is showing fuel stains around the right wing sump. These were visible when I bought the plane, the owner said he had some leak issues when running mogas on that side and they went away when he went back to aviation fuel. The leak has resumed, there were blue streaks back to the rear of the wing after the last flight.
I'm not seeing any sealant visible on the threads for the fuel sump. I'm hoping the leak is from there and not from the riveted base above it. Shall I drain the tank, unscrew the sump and apply sealant to the threads? What sealant is correct and where can I order a replacement sump if I damage this one in the process?
