I would like to check the timing of my slick magnetos on my RV14A. I know there are many YouTube videos but would like a few things clarifying.
I would like to use my home made buzzer (buzzer & battery & 2 crocodile leads). I am aware cylinder 1 needs to be on the compression stroke with top spark plugs remove, then rotate backwards just past the 20 degree BTDC.
With the master switch on and the key switch to Both connect one buzzer lead to the P terminal and one buzzer lead to ground on one of the magnetos and rotate the prop very gradually towards the 20 degrees BTDC where I should here the buzzer start or maybe the opposite occurrence the buzzer stops buzzing.
Will this arrangement work with the buzzer and/or do I need to disconnect the P leads from the magnetos before connecting my buzzer lead?
Any advice would be welcome.
John
John
