Thanks for that. This, and Van's acknowledgement that this part can't be replaced, has pretty much sealed my belief that the project needs to go to the salvage yard.
Bob -
We’ve known each other casually for many, many years….and your signature (EAA Chapter MVP, Tech Counselor, FAAST Team….) tells us how involved you have been - and have stayed in - experimental aviation. So you know that there are high points and low points - sometimes VERY low points - in homebuilding. In fact, I just wrote a segment of a series I am running devoted to the very problem of “the insurmountable problem”. Everyone runs into them at some point - no one gets through the build of something as complex as an airplane without at least one. You’ve been there before with your -7….and you triumphed over it with the help of friends in teh community.
Van’s didn’t tell you that the part couldn’t be replaced, they said:
Unfortunately, there is no easy way to get in to replace that fuel line. It is something that is not done very often.
They said it would be hard…..
“We choose to go to the moon not because it is easy, but because it is hard!” … remember that old gem?
Everything is fixable - sometimes it’s just a bit (or a lot) harder than other times. I have seen all sorts of repairs to airplane primary structure that non-engineers wouldn’t believe. The Apollo 13 crew was effectively doomed by their oxygen tank explosion - but a whole bunch of guys figured out how to bring them home anyways.
OK - so let’s say that you personally have run out of gas on this at your age. I get that - I really do. In that case, if you are truly ready to write the whole thing off (salvage isn’t worth much) then donate it to a cause like an EAA chapter kids project, or an A&P school. Have a good lawyer write up a contract if you’re worried about the liability (although since it is not registered, and is just a pile of parts, I seriously doubt there is much based on history). Fixing a problem in a metal airplane project isn’t rocket science (I don’t actually write that phrase very often….) - its just drilling hole sand riveting in doublers.
Or….get a bunch of those Minnesota friends over, make some coffee and “a little lunch”, and get them to fix it so that you can move on. It’s inspirational to the next generation not to give up on it, and yes - anything can be fixed. It’s just sometimes harder.
It’s OK to “retire from the field” at some point - everyone has to, eventually. But do it because you’re ready - not because you’re frustrated.
Just thoughts from this morning’s cup of coffee…..
Paul
